Lenovo ThinkPad X1 Tablet Gen 3 LCFC NM-B271 Rev 1.0 Schematic
This Lenovo Miix730 & ThinkX1 motherboard, manufactured by LC Future Center, is built on the Intel Kabylake Platform U-Series. The system management is handled by a MEC1650 EC/KBC, with the BIOS stored on a W25Q128FVPIQ SPI flash IC. Audio processing is split between an ALC3277 audio codec and an ALC3291 audio DSP. The board supports up to 16GB of LPDDR3 memory in a Memory Down configuration. Power management includes a BQ25700 battery charger, with core voltage regulation provided by NCP81218 and NCP81382 controllers. Thunderbolt connectivity is managed by a JHL6540 Alpine Ridge controller, while USB-C PD control is handled by TPS65982 and TPS65982D controllers. The HDMI interface uses a PS8338 level shifter, and a TS3USB31E USB hub IC is present for USB switching.
A: The BIOS is stored on a W25Q128FVPIQ SPI flash IC.
A: The embedded controller is a MEC1650.
A: The charging IC is a BQ25700.
Q: What memory type and configuration does this board use?
A: The board uses LPDDR3 memory in a Memory Down configuration, supporting up to 16GB.
| Brand | Lenovo |
| Model | Miix730 & ThinkX1 |
| Date | Tuesday, October 31, 2017 |
| CPU Platform | Intel Kabylake Platform U-Series |
| EC / KBC | MEC1650 |
| Audio Codec | ALC3277 |
| Audio DSP | ALC3291 |
| BIOS / SPI Flash | W25Q128FVPIQ |
| Charging IC | BQ25700 |
| RAM Type | LPDDR3 |
| RAM Architecture | Memory Down |
| RAM Quantity / Slots | Max 16GB |
| Card Reader IC | DBM |
| LAN IC | JHL6540 Alpine Ridge |
| WiFi / WLAN IC | WLAN Type B NGFF Conn |
| HDMI Level Shifter | PS8338 |
| USB-C Controller | TPS65982 / TPS65982D |
| PD Controller | TPS65982DA |
| Power IC(s) | NCP81218, NCP81382, BD91364, BU90104GWZ, NB682, NB686 |
| Charger Architecture | BQ25700 |
| Thermal Sensor | BMI055 |
| USB Hub IC | TS3USB31E |
Kaby Lake
MEC1650
ALC3277
W25Q128FVPIQ
BQ25700
LPDDR3
JHL6540 ALPINE RIDGE
PS8338
TPS65982
TPS65982D
TPS65982DA
BD91364
BU90104GWZ
NB682
NB686
NCP81218
NCP81382
BMI055
TS3USB31E
Kaby Lake
MEC1650
ALC3277
W25Q128FVPIQ
BQ25700
LPDDR3
PS8338
TPS65982
TPS65982D
TPS65982DA
BD91364
BU90104GWZ
NB682
NB686
NCP81218
NCP81382
BMI055
TS3USB31E
