dell latitude xt tablet pc e5400 parker mb a00 06240-1 4s701 0814w r-1 1
The Wistron Parker-1 motherboard, project code 91.4S701.001 and board number 48.4S701.001, is designed for Intel Yonah or Merom ULV mobile processors on an FSB 533MHz platform. The system utilizes an ATI SB600 southbridge with integrated graphics supporting dual DDR2 SODIMM channels at 533/667MHz. Embedded control is handled by an SMSC MEC5025 EC/KBC with SPI programmability, paired with a 2MB SPI flash BIOS. Power management includes an ISL88731 battery charger, ISL6236/MAX8778 system DC/DC converters, an ADP3207 CPU core regulator, a TPS51100 LDO, and a MAX8794 regulator. Networking is provided by a BCM5756M Gigabit LAN controller, audio by a STAC 9205 Azalia codec, and thermal monitoring by an EMC4001 sensor. The board also features a TI 7402 card reader and an SMSC ECE5021 SIO expander.
Q: What EC/KBC is used on this motherboard and is it programmable?
A: The EC/KBC is an SMSC MEC5025, and it is programmable via SPI.
A: The motherboard uses a 2MB SPI flash for the BIOS.
Q: What is the charging IC on this board?
A: The battery charging IC is an ISL88731.
Q: What CPU platform does this motherboard support?
A: The board supports Intel Yonah or Merom ULV processors with an FSB of 533MHz.
| Model | Parker-1 |
| Project Code | 91.4S701.001 |
| Board Number | 48.4S701.001 |
| Revision | 06240-1 |
| Date | 08/14/2007 |
| Document Number | A3153 |
| CPU Platform | Yonah / Merom ULV |
| EC / KBC | SMSC MEC5025 |
| EC/KBC Programmable | SPI |
| Audio Codec | STAC 9205 |
| BIOS / SPI Flash | SPI FLASH 2MB |
| Charging IC | ISL88731 |
| Power IC(s) | ISL6236/MAX8778, ADP3207, TPS51100, MAX8794 |
| RAM Type | DDRII 533/667MHz |
| RAM Architecture | UNBUFFERED DDR2 SODIMM |
| RAM Quantity / Slots | 200-PIN DDR2 SODIMM |
| LAN IC | BCM5756M |
| WiFi / WLAN IC | BCM5756M |
| Card Reader IC | TI 7402 |
| Thermal Sensor | EMC4001 |
| GPU Type | INTEGRATED GRAPHICS |
| Graphics Architecture | ATI SB600 |
| PCH / Southbridge | ATI SB600 |
91.4S701.001
48.4S701.001
Merom-ULV
Yonah
MEC5025
STAC9205
ISL88731
ADP3207
ISL6236
MAX8778
MAX8794
TPS51100
BCM5756M
7402
EMC4001
ATI SB600
SB600
91.4S701.001
48.4S701.001
Merom-ULV
Yonah
MEC5025
STAC9205
ISL88731
ADP3207
ISL6236
MAX8778
MAX8794
TPS51100
BCM5756M
7402
EMC4001
ATI SB600
SB600
