Schematic dell inspiron n4010 quanta um8b discrete rev1a schematic
dell inspiron n4010 quanta um8b discrete_rev1a schematic
dell inspiron n4010=1=quanta um8b discrete_rev1a.pdf
BrandQuanta Computer Inc.
Project CodeUM8B DIS
Revision1A
DateFriday, February 05, 2010
CPU PlatformArrandale
PCH / SouthbridgeIbex Peak-m
GPU TypeATI Madison
Graphics ArchitectureUMA VGA CORE
EC / KBCITE 8502
Audio CodecALC269-GR
BIOS / SPI Flash4M ROM
Card Reader ICRTS5138
LAN ICAtheros AR8152
RAM TypeDDR3
RAM ArchitectureSODIMM 127mm X 25mm
RAM Quantity / Slots2
Charging ICBQ24745
Thermal SensorGMT G990/EMC1422-1-AIZL-TR
Clock Generator9LRS3197
HDMI Level ShifterSN75LVCP412
This Quanta UM8B DIS motherboard revision 1A, dated February 5, 2010, is built around an Intel Arrandale CPU platform paired with an Ibex Peak-m PCH. Graphics are handled by an ATI Madison GPU with UMA VGA core support. The system uses two DDR3 SODIMM slots (127mm x 25mm) for memory expansion. The embedded controller is an ITE 8502, and the audio codec is an ALC269-GR. A 4M ROM is used for BIOS/SPI flash storage. Networking is provided by an Atheros AR8152 LAN IC. The board features an RTS5138 card reader, a BQ24745 charging IC, and a GMT G990/EMC1422-1-AIZL-TR thermal sensor. Clock generation is handled by a 9LRS3197 clock generator, and an SN75LVCP412 HDMI level shifter is present.
A: The embedded controller is an ITE 8502.
A: The BIOS/SPI flash is a 4M ROM.
A: The charging IC is a BQ24745.
Q: What is the graphics configuration on this motherboard?
A: The motherboard uses an ATI Madison GPU with UMA VGA core support.
  • Dell Inspiron N4010=1=Quanta UM8B Discrete_Rev1A.zip
