dell n4010 quanta um8 smallboard
This Quanta UM81A motherboard schematic, dated February 1, 2010, is documented by Quanta Computer. The board utilizes an Atheros AR8152-AL1A LAN IC, with references to the AR8151 and AR8152 chip families for the Ethernet controller. The design includes a dedicated LAN section with an RJ-45 connector and associated magnetics.
Q: What LAN IC is used on this Quanta UM81A motherboard?
A: The primary LAN IC is an Atheros AR8152-AL1A, with the schematic also referencing the AR8151 and AR8152 chip families.
This Quanta Computer UM81A motherboard schematic, dated November 24, 2009, integrates an Atheros AR8152-AL1A or AR8151 LAN controller for wired networking. The design includes a VGA connector section with impedance-controlled RGB traces and DDC support, alongside a DB CONN/POWER BOTTON interface. The LAN section features a 25MHz crystal, an NS0013B LF transformer, and an RJ45 connector with integrated LEDs for link and activity status. The schematic also documents screw hole mounting points for the chassis.
Q: What LAN controller ICs are used on this motherboard?
A: The schematic lists Atheros AR8152-AL1A, AR8151, and AR8152 as the LAN controller ICs.
Q: What is the board number and manufacturer of this motherboard?
A: The board is a Quanta Computer UM81A, dated November 24, 2009.
The Quanta UM81A motherboard, documented on December 31, 2009, is a Quanta Computer design. The board integrates an Atheros AR8152-AL1A or AR8151 LAN controller for wired networking, supported by an NS0013B LF transformer module. The schematic details the LAN section, VGA connector, and power button interface, with specific layout notes for impedance control on the VGA RGB traces.
Q: What LAN ICs are used on this motherboard?
A: The motherboard uses an Atheros AR8152-AL1A or AR8151 LAN controller, paired with an NS0013B LF transformer.
This Quanta Computer UM81A motherboard schematic, dated Monday, February 01, 2010, includes documentation for Mini-Card (WLAN) and Mini-Card (WWAN) connectors. The WLAN connector supports PCI Express and USB interfaces, with signals such as PCIE_TXP/N, PCIE_RXP/N, CLK_PCIE_WLANP/N, and USBP4+/-. The WWAN connector also supports USB and UIM signals, including USBP5+/- and UIM_PWR, UIM_DATA, UIM_RESET, UIM_CLK, and UIM_VPP. Power rails documented include +1.5V_RUN, +3.3V_RUN, +5V_SUS, and +5V_RUN. The board features a TB CONN header (CN1) with 80 pins.
A: The motherboard is a Quanta Computer UM81A.
Q: What is the date of this schematic?
A: The schematic is dated Monday, February 01, 2010.
This Quanta Computer UM81A motherboard schematic, dated Wednesday, November 25, 2009, documents a platform designed for Mini-Card WLAN and WWAN connectivity. The board integrates multiple power rails including +1.5V_RUN, +3.3V_RUN, +5V_RUN, and +5V_SUS to support its subsystems. The schematic details a Mini PCI Express connector for WLAN and a separate Mini PCI Express connector for WWAN, both with associated UIM interface signals. The design includes provisions for audio, USB, and PCI Express interfaces, with specific layout notes for component placement to minimize signal stubs and prevent backdrive during Wake-on-WLAN operation.
A: The schematic is dated Wednesday, November 25, 2009.
This Quanta Computer UM81A motherboard schematic, dated Tuesday, December 29, 2009, details the board's connector and Mini-Card interfaces. The documentation includes a main BTB (Board-to-Board) connector page and separate pages for WLAN and WWAN Mini-Card connectors. The WLAN Mini-Card connector supports PCI Express and USB interfaces, with signals for WLAN_SMBCLK, WLAN_SMBDATA, and COEX coexistence lines. The WWAN Mini-Card connector includes UIM interface signals for cellular connectivity. Power rails distributed to these connectors include +3.3V_RUN, +1.5V_RUN, +5V_SUS, and +5V_RUN.
Q: What is the brand and model of this motherboard?
A: The schematic is dated Tuesday, December 29, 2009.
This Quanta UM81A motherboard schematic, dated Thursday, January 28, 2010, is a Quanta Computer design. The document covers the power button section, including a SKRBAAE010 switch and associated components such as resistors and LEDs. The board utilizes a hot bar cable connector and various header connectors for power and LED signaling.
Q: What is the board number for this Quanta motherboard?
A: The board number is UM81A.
Q: What is the document date of this schematic?
A: The schematic is dated Thursday, January 28, 2010.
This Quanta UM81A motherboard schematic, dated November 23, 2009, is documented by Quanta Computer. The power button section includes a SKRBAAE010 switch and white LED indicators for power and breathing LED functions. The document provides the foundational board identification for this Quanta platform.
A: The schematic is dated Monday, November 23, 2009.
This Quanta UM81A motherboard schematic, documented under number HCJM5005010 and dated January 28, 2010, is a compact design featuring a button board interface. The schematic includes a hot bar cable connector (CON1) and a tactile switch (SKQGAB) for power or lid switch functionality. The design incorporates basic passive components such as a 1M ohm resistor (R1) and a 0.1uF/16V capacitor (C10) for signal conditioning. The board utilizes an EM-6781-T3 component (U1) for voltage regulation or timing purposes. The schematic is a single-sheet document from Quanta Computer, indicating a focused subsystem or daughterboard design rather than a full motherboard layout.
Q: What is the document number for this Quanta UM81A schematic?
A: The document number is HCJM5005010.
Q: What is the date of this Quanta UM81A schematic?
Q: What type of connector is used for the cable interface on this board?
A: The board uses a hot bar cable connector, designated as CON1.
This Quanta UM81A motherboard schematic, dated November 25, 2009, is identified by document number HCJM5005010. The schematic includes a button board page with components such as the EM-6781-T3 and SKQGAB tactile switches. The board utilizes header CON1 (HEADER 6_1) and various passive components including a 1M resistor and a 0.1uF/16V capacitor. The document is authored by Quanta Computer and provides the foundational schematic reference for this specific motherboard model.
| Brand | QUANTA |
| Model | UM81A |
| Board Number | UM81A |
| Date | Monday, February 01, 2010 |
| LAN IC | ar8152-al1a/"]AR8152-AL1A[/URL] |
| LAN IC | AR8151 |
| LAN IC | AR8152 |
| Brand | QUANTA COMPUTER |
| Model | UM81A |
| Date | Tuesday, November 24, 2009 |
| LAN IC | AR8151 |
| LAN IC | AR8152 |
| Brand | QUANTA |
| Model | UM81A |
| Date | Thursday, December 31, 2009 |
| LAN IC | AR8151 |
| LAN IC | AR8152 |
| LAN IC | Atheros |
| LAN IC | NS0013B LF |
| Model | UM81A |
| Model | UM81A |
| Date | Wednesday, November 25, 2009 |
| Model | UM81A |
| Date | Tuesday, December 29, 2009 |
| Brand | QUANTA |
| Model | UM81A |
| Date | Thursday, January 28, 2010 |
| Brand | QUANTA |
| Model | UM81A |
| Date | Monday, November 23, 2009 |
| Brand | QUANTA |
| Model | UM81A |
| Project Code | UM81A |
| Document Number | HCJM5005010 |
| Brand | QUANTA |
| Model | UM81A |
