dell vostro 1088 quanta vm8g intel discrete gfx_rev1b schematic
dell vostro 1088=1=quanta vm8g intel discrete gfx_rev1b.pdf
The Quanta Computer VM8G1B is a motherboard revision F3B designed for the Penryn CPU platform using a 478 Micro-FCPGA socket. It is built around the Intel Cantiga GMCH and ICH9-M southbridge, supporting DDR2-SODIMM memory across two slots. Graphics are handled by a discrete ATI M92-S2 LP GPU. The embedded controller is an ITE8502, and the system BIOS is stored in a 2M byte flash IC. Audio is managed by a Conexant CX20583-10z codec, while networking is provided by a Realtek RTL8111DL Gigabit LAN controller. The charging subsystem is based on the MAX8731A charger IC. Wireless connectivity is supported via an SLG8SP513V module, and a Ricoh R5U230 controller handles the 3-in-1 card reader functionality.
A: The embedded controller is an ITE8502.
A: The BIOS flash is 2M bytes.
A: The charging IC is a MAX8731A.
A: The motherboard uses a discrete ATI M92-S2 LP GPU.
| Brand | QUANTA COMPUTER |
| Model | VM8G1B |
| Board Number | VM8G1B |
| Revision | F3B |
| Date | Saturday, June 06, 2009 |
| CPU Platform | Penryn |
| CPU Socket | 478 Micro-FCPGA |
| GPU Type | ATI M92-S2 LP |
| Graphics Architecture | Discrete GFX |
| EC / KBC | ITE8502 |
| Audio Codec | CX20583-10z |
| BIOS / SPI Flash | 2M bytes |
| Charging IC | MAX8731A |
| RAM Type | DDR2 |
| RAM Architecture | DDR2-SODIMM |
| LAN IC | RTL8111DL |
| WiFi / WLAN IC | SLG8SP513V |
| Card Reader IC | R5U230 |
