dell inspiron mini 10 compal_la-5162p_rev0.2 schematic
dell inspiron mini 10=1=compal_la-5162p_rev0.2.pdf
This Compal LA-5162P motherboard, revision 0.2(X01), is designed for the Dell Liver-Pool 13.3" platform. It supports the Intel Penryn CPU in a Socket P package paired with the Cantiga (GM45) chipset and ICH9-M southbridge. The board is configurable for either Discrete (DIS) graphics using an M92-S2-LP 512 MB GPU or UMA graphics, with separate project codes KAM01 and KAM00 respectively. The system uses DDR2 memory across two DIMM slots. The embedded controller is a KB926D3, and the BIOS SPI flash is a 2Mb MX25L1605AM2C. Audio is handled by a 92HD81B codec, and networking is provided by a Realtek RTL8111DL Gigabit LAN controller. Power management is managed by a suite of ICs including TPS51117RGYR, TPS51427, MAX8794, ISL6266ACRZ-T, and ISL6268CAZ-T for charging. The board also features an OZ888GS0L3NR card reader, a PS8101T HDMI level shifter, and a SLG8LP554VTR clock generator.
A: The BIOS SPI flash is an MX25L1605AM2C with a capacity of 2Mb.
Q: Is the EC/KBC programmable on this motherboard?
A: The EC/KBC is a KB926D3. The schematic does not explicitly indicate programmable capability.
Q: Does this motherboard support dGPU to UMA conversion?
A: Yes. The board is designed with two project codes:
| Model | Liver-Pool 13.3" |
| Project Code | KAM01(DIS) / KAM00(UMA) |
| Board Number | LA-5162P |
| Revision | 0.2(X01) |
| Date | 2009/04/20 |
| CPU Platform | Penryn + Cantiga(GM45) + ICH9-M |
| CPU Socket | Socket P |
| PCH / Southbridge | ICH9-M |
| GPU Type | M92-S2-LP 512 MB (Discrete Only) |
| Graphics Architecture | Discrete (DIS) / UMA |
| dGPU to UMA Conversion Support | Yes (KAM01 DIS / KAM00 UMA) |
| EC / KBC | KB926D3 |
| Audio Codec | 92HD81B |
| BIOS / SPI Flash | MX25L1605AM2C |
| BIOS Flash Capacity | 2Mb |
| Charging IC | ISL6268CAZ-T |
| Power IC(s) | TPS51117RGYR, TPS51427, MAX8794, ISL6266ACRZ-T, RT9026GFP, TPS71718DCKR, RT9013 |
| RAM Type | DDRII |
| RAM Architecture | DDRII-DIMM X2 |
| Card Reader IC | OZ888GS0L3NR |
| LAN IC | RTL8111DL |
| WiFi / WLAN IC | Mini Card WiFi |
| HDMI Level Shifter | PS8101T |
| Thermal Sensor | 1402 |
| Clock Generator | SLG8LP554VTR |
KAM00
KAM01
LA-5162P
Cantiga
ICH9
KB926D3
92HD81B
MX25L1605AM2C
ISL6268CAZ-T
ISL6266ACRZ-T
MAX8794
RT9013
RT9026GFP
TPS51117RGYR
TPS51427
TPS71718DCKR
OZ888GS0L3NR
RTL8111DL
PS8101T
1402
SLG8LP554VTR
KAM00
KAM01
LA-5162P
Cantiga
ICH9
KB926D3
92HD81B
MX25L1605AM2C
ISL6268CAZ-T
ISL6266ACRZ-T
MAX8794
RT9013
RT9026GFP
TPS51117RGYR
TPS51427
TPS71718DCKR
OZ888GS0L3NR
RTL8111DL
PS8101T
1402
SLG8LP554VTR
