hp mini 1000-1030nr 6050a2215101-mb-a04 schematic
hp mini 1000-1030nr=1=6050a2215101-mb-a04.pdf
This Inventec Harbour CSA351 motherboard, board number 6050A2215101 revision A02 dated 21-Aug-2008, is built around the Intel Diamondville-SC platform with an ICH7M southbridge. Graphics are handled by the integrated 945GSE/945GMS controller. The system memory architecture consists of a single DDR2 channel with one DDR2 SODIMM0 slot. The embedded controller is an ITE8512E, and the BIOS SPI flash is an SST25VF016. Power management is handled by a TI BQ24721C charger IC, with system power regulation provided by TPS51125, TPS51610, TPS51100, and GMT G966. Audio is managed by an IDT 92HD75B2 codec with a TPA6040A amplifier. Networking is provided by a Marvell 88E8040 LAN controller, and a card reader is implemented via an AU6336 controller. The clock generator is an ICS9LPRS365.
Q: What is the board number and revision for this Inventec Harbour motherboard?
A: The board number is 6050A2215101, revision A02, dated 21-Aug-2008.
Q: What BIOS SPI flash IC is used on this motherboard?
A: The BIOS SPI flash IC is an SST25VF016.
A: The EC/KBC controller is an ITE8512E.
A: The charging IC is a TI BQ24721C.
A: The memory architecture is a single DDR2 channel with one DDR2 SODIMM0 slot.
| Brand | Inventec |
| Model | Harbour |
| Project Code | CSA351 |
| Board Number | 6050A2215101 |
| Revision | A02 |
| Date | 21-Aug-2008 |
| CPU Platform | Diamondville-SC |
| PCH / Southbridge | ICH7M |
| GPU Type | 945GSE |
| Graphics Architecture | 945GMS |
| EC / KBC | ITE8512E |
| Audio Codec | IDT 92HD75B2 |
| BIOS / SPI Flash | SST25VF016 |
| Charging IC | TI BQ24721C |
| Power IC(s) | TPS51125, TPS51610, TPS51100, GMT G966 |
| RAM Type | DDR2 |
| RAM Architecture | Single DDR2 Channel |
| RAM Quantity / Slots | 1x DDR2 SODIMM0 |
| LAN IC | 88E8040 |
| Card Reader IC | AU6336 |
| Clock Generator | ICS9LPRS365 |
| Audio Amplifier | TPA6040A |
CSA351
6050A2215101
Diamondville
ICH7M
945GSE
945GMS
IT8512E
92HD75B2
SST25VF016
BQ24721C
GMT G966
TPS51100
TPS51125
TPS51610
88E8040
AU6336
ICS9LPRS365
TPA6040A
CSA351
6050A2215101
Diamondville
ICH7M
945GSE
945GMS
IT8512E
92HD75B2
SST25VF016
BQ24721C
GMT G966
TPS51100
TPS51125
TPS51610
88E8040
AU6336
ICS9LPRS365
TPA6040A
