dell inspiron mini 1210 compal la-4501p_rev1.0 schematic
dell inspiron mini 1210=1=compal la-4501p_rev1.0.pdf
The Compal KIU00 LA-4501P Rev 1.0 motherboard, dated 2008-08-20, is built around the Intel Silverthrone CPU platform (1.33G/1.6G) with an FSB of 533MHz, paired with the SCH- Poulsbo Southbridge. Memory configuration consists of four DDR2 64MX16 chips operating in Single Channel mode. The embedded controller is a KB926, and the audio subsystem is managed by an ALC 269 codec. System BIOS is stored in a dedicated SPI flash. Networking is handled by a Realtek RTL8102EL LAN IC, while a Realtek RTS5158 card reader provides SD/MMC/MS support. The charging circuit is labeled DCIN/CHARGER, and the clock generator is a UMS9610. Wireless connectivity is provided by an LBMA46LCS1 module.
A: The embedded controller is a KB926.
A: The audio codec is an ALC 269.
A: The LAN IC is a Realtek RTL8102EL.
Q: What card reader IC is used on this motherboard?
A: The card reader IC is a Realtek RTS5158.
Q: What clock generator is used on this motherboard?
A: The clock generator is a UMS9610.
| Model | KIU00 |
| Project Code | KIU00 |
| Board Number | LA-4501P |
| Date | 2008-08-20 |
| CPU Platform | Silverthrone |
| CPU Model | CPU-Silverthrone 1.33G/1.6G |
| PCH / Southbridge | SCH- Poulsbo |
| EC / KBC | KB926 |
| Audio Codec | ALC 269 |
| BIOS / SPI Flash | BIOS |
| RAM Type | DDR2 |
| RAM Quantity / Slots | 4pcs |
| LAN IC | RTL8102EL |
| Card Reader IC | RTS5158 |
| Charging IC | DCIN/CHARGER |
| Clock Gen. | UMS9610 |
| WiFi / WLAN IC | LBMA46LCS1 |
