dell inspiron 9100 compal_la-1711_rev x03-h schematic
dell inspiron 9100=1=compal_la-1711_rev x03-h.pdf
This Compal LA-1711 X03-H schematic, dated October 14, 2003, documents the motherboard platform for Dell Inspiron models (Nimitz and Alcatraz). The core architecture is built around an Intel Prescott FCPGA CPU and a Springdale (GMCH) graphics and memory controller hub, paired with an ICH5 southbridge. The system memory configuration supports DDR RAM across two channels, each with four banks, utilizing SO-DIMM modules. The BIOS and EC/KBC functions are handled by a single SST39VF080 flash IC. Audio is managed by a STAC9750 AC97 codec, while networking is provided by either a BCM5705M or BCM4401 LAN controller. Thermal monitoring is performed by an ADT7460 sensor, and the system includes a PCI7510/PCI4510 CardBus controller for SmartCard and 1394 support.
A: The BIOS and EC/KBC functions are handled by a single SST39VF080 flash IC.
A: The motherboard supports DDR memory across two channels (Channel A and Channel B), each with four banks (BANK 0, 1, 2, 3), using SO-DIMM modules.
Q: What LAN IC options are available on this motherboard?
A: The schematic lists two LAN IC options: a BCM5705M for 1000Mbps and a BCM4401 for 10/100Mbps.
Q: What is the CPU platform and PCH used on this motherboard?
A: The platform is based on an Intel Prescott CPU and an ICH5 southbridge, with a Springdale (GMCH) for graphics and memory control.
| Model | Inspiron (Nimitz/Alcatraz) |
| Document Number | LA-1711 |
| Revision | X03-H |
| Date | Tuesday, October 14, 2003 |
| CPU Platform | Prescott & Springdale |
| CPU Model | Prescott |
| PCH / Southbridge | ICH5 |
| GPU Type | RG828SD |
| Graphics Architecture | Springdale (GMCH) |
| EC / KBC | SST39VF080 |
| Audio Codec | STAC9750 |
| BIOS / SPI Flash | SST39VF080 |
| Charging IC | BATTIN |
| RAM Architecture | Channel A SO-DIMM, Channel B SO-DIMM |
| RAM Quantity / Slots | BANK 0, 1, 2, 3 (Channel A), BANK 0, 1, 2, 3 (Channel B) |
| Thermal Sensor | ADT7460 |
| Card Reader IC | PCI7510/PCI4510 |
| LAN IC | BCM5705M, BCM4401 |
| WiFi / WLAN IC | MINI PCI |
Prescott
Springdale
Prescott
ICH5
RG828SD
Springdale (GMCH)
SST39VF080
STAC9750
SST39VF080
DDR
ADT7460
PCI4510
PCI7510
BCM4401
BCM5705M
Prescott
Springdale
Prescott
ICH5
RG828SD
Springdale (GMCH)
SST39VF080
STAC9750
SST39VF080
DDR
ADT7460
PCI4510
PCI7510
BCM4401
BCM5705M
