acer aspire 9100 compal_la-2351_rev1b schematic
acer aspire 9100=1=compal_la-2351_rev1b.pdf
The Compal EDL71 LA-23511B Rev 1B motherboard is designed for the Intel Pentium-M processor in a uFCPGA socket, paired with the Intel Alviso chipset and ICH6-M southbridge. Graphics are handled by an ATI M24 GPU with a dedicated frame buffer. The board supports two DDRI-DIMM slots across four memory banks. Power management is handled by a MAX1902 DC/DC converter for 3V/5V/12V rails, a MAX1532 for CPU core, an ALP5331 for 1.25V, a MAX8743 for 1.5V/VCCP, and a FAN5234 for 2.5V, with charging controlled by a PMB3887 IC. Audio is provided by an ALC250 AC97 codec, networking by an RTL8110SBL/8100CL LAN controller, and card reading by an ENE CB712 controller. Thermal monitoring uses G781 sensors for both CPU and VGA. The EC flash ROM is an SST39VF040 parallel flash device.
A: The board number is LA-23511B, revision 1B, manufactured by Compal Electronics, Inc.
Q: What CPU and chipset does this motherboard use?
A: It uses an Intel Pentium-M processor (uFCPGA socket) with the Intel Alviso chipset and ICH6-M southbridge.
Q: What type of memory is supported and how many slots are available?
A: The board supports DDRI memory via two DIMM slots, configured across four banks (0, 1, 2, 3).
Q: What EC flash ROM is used on this motherboard?
A: The EC flash ROM is an SST39VF040 parallel flash device.
| Model | EDL71 |
| Board Number | LA-23511B |
| Revision | 1B |
| Date | 2005-02-25 |
| CPU Platform | Intel Alviso + ICH6-M |
| CPU Model | Pentium-M |
| CPU Socket | uFCPGA |
| PCH / Southbridge | ICH6-M |
| GPU Type | ATI M24 |
| Audio Codec | ALC250 |
| Charging IC | PMB3887 |
| Charger Architecture | MAX1902 DC/DC (3V/5V/12V) |
| Power IC(s) | MAX1532 DC/DC (CPU_CORE), ALP5331 DC/DC (1.25V), MAX8743 DC/DC (1.5V/VCCP), FAN5234 DC/DC (2.5V) |
| RAM Type | DDRI |
| RAM Architecture | DDRI-DIMM X2, BANK 0, 1, 2, 3 |
| Card Reader IC | ENE CB712 |
| LAN IC | RTL8110SBL/8100CL |
| WiFi / WLAN IC | Minipci CONN X2 |
| Thermal Sensor | G781 (CPU), G781-1 (VGA) |
| EC Flash / ROM | SST39VF040 |
| Document Number | EDL71 LA-23511B |
LA-23511B
Alviso
Pentium M
ICH6
M24
ALC250
PMB3887
ALP5331 DC
DC (1.5V
FAN5234 DC
MAX1532 DC
MAX8743 DC
DDR
CB712
8100CL
RTL8110SBL
Minipci CONN X2
G781
G781-1
SST39VF040
LA-23511B
Alviso
Pentium M
ICH6
M24
ALC250
PMB3887
ALP5331 DC
DC (1.5V
FAN5234 DC
MAX1532 DC
MAX8743 DC
DDR
CB712
8100CL
RTL8110SBL
Minipci CONN X2
G781
G781-1
SST39VF040
