Schematic fujitsu siemens lifebook n6010 quanta aw1 rev1b schematic
fujitsu siemens lifebook n6010 quanta aw1_rev1b schematic
fujitsu siemens lifebook n6010=1=quanta aw1_rev1b.pdf
BrandQUANTA COMPUTER
ModelAW1 M/B
Motherboard ManufacturerQUANTA COMPUTER
Board NumberAW1 M/B
Revision1B
DateWednesday, August 11, 2004
CPU PlatformMOBILE PRESCOTT [URL="https://dr-bios.com/components/cpu-platform/478-mpbga/"]478 PIN (MPBGA)[/URL]
CPU Socket478 PIN (MPBGA)
PCH / SouthbridgeSIS964L
GPU TypeATI M1101
Graphics ArchitectureAGP 1.5V, 66MHz
EC / KBCPC87591
EC/KBC Package176 Pins LQFP
Audio CodecSTAC9752A
BIOS / SPI FlashFLASH
Charging ICBATTERY CHARGER
RAM TypeDDR SDRAM 2.5V, 400MHz
RAM ArchitectureDDR-SODIMM1, DDR-SODIMM2
RAM Quantity / Slots2
LAN ICBCM5788
WiFi / WLAN ICMINI-PCI
Card Reader ICTI PCI7411
Clock GeneratorICS952018
Clock BufferICS93741
Document NumberA3242
The Quanta Computer AW1 M/B revision 1B is a Mobile Prescott platform motherboard utilizing a 478-pin MPBGA CPU socket. The system architecture is built around the SIS655FX northbridge and SIS964L southbridge, supporting dual DDR-SODIMM slots for DDR SDRAM at 400MHz. Graphics are handled by an ATI M1101 GPU connected via AGP 1.5V. The embedded controller is a PC87591 in a 176-pin LQFP package, and the system BIOS is stored in a FLASH device. Audio is provided by a STAC9752A codec, networking by a Broadcom BCM5788 LAN controller, and expansion includes a Mini-PCI slot and a TI PCI7411 CardBus controller. Clock generation is managed by an ICS952018 generator with an ICS93741 DDR clock buffer. The board also integrates a battery charger subsystem and an AC97 audio interface.
A: The EC/KBC is a PC87591 in a 176-pin LQFP package.
A: The audio codec is a STAC9752A.
A: The LAN controller is a Broadcom BCM5788.
Q: What is the clock generator and buffer configuration?
A: The clock generator is an ICS952018, and the DDR clock buffer is an ICS93741.
  • Fujitsu Siemens LifeBook N6010=1=Quanta AW1_Rev1B.zip
