Schematic MSI MS-9573 5U Rev X03 0A 120 140 Schematic
BrandDell Computer Corporation
Motherboard ManufacturerDell Computer Corporation
Project CodePE2800
Board NumberSVF13142
Revision0.32
Date2/23/2004
Drawing NumberX03-4433
Document TitlePCI Express Hot Plug
Hot Plug ControllerMIC2591
Hot Plug Controller PackageSO-8
Hot Plug MOSFET (N-Channel)SI4420DY
Hot Plug MOSFET (P-Channel)SI4435DY
Hot Plug MOSFET PackageSO-8
This Dell Computer Corporation schematic, dated 2/23/2004, documents the PCI Express Hot Plug circuitry for the PE2800 project, board number SVF13142, drawing number X03-4433, revision 0.32. The hot plug controller is a MIC2591 in an SO-8 package, managing power delivery to the PCI Express slot. The design utilizes SI4420DY N-channel and SI4435DY P-channel MOSFETs, both in SO-8 packages, for power switching. The schematic includes detailed engineering notes on current limit settings, fault timing, and component value changes across multiple revision dates, including adjustments for the MIC2591A variant.
Q: What is the hot plug controller IC used on this Dell PE2800 motherboard?
A: The hot plug controller is a MIC2591 in an SO-8 package.
Q: What MOSFETs are used for the PCI Express hot plug power switching?
A: The design uses SI4420DY N-channel MOSFETs and SI4435DY P-channel MOSFETs, both in SO-8 packages.
Q: What is the board number and project code for this schematic?
A: The board number is SVF13142, and the project code is PE2800.
BrandDell
Drawing NumberF1314
RevisionX03
Date1/30/2004
CPU Platformdobson-nq80332/"]Dobson (NQ80332)[/URL]
PCH / SouthbridgePXH (NQ80000PXH-D, NQ80001)
RAM TypeDDR2 400
RAM ArchitectureDIMM
RAM Quantity / Slots4
LAN ICLSI 1030
SCSI ControllerLSI 1030
SCSI ArchitectureU320
PCI Express Configurationx8, x4, x8 SLOT
PCI-X ConfigurationPCIX 1.0 (133 MHz)
Legacy PCI Configuration32b/33M 5V
Hot Plug SupportPCI Express Hot Plug
ROMB SupportROMB DIMM
Flash / NVRAMDobson Flash NVRAM
CPLDCPLD, Spare Gates
I2C IsolationI2C Isolation, I2C Block Diagram, I2C Address Chart
Form Factor5U Riser
Connector Type202 pin Gold Fingers
Board NumberF1314
Document NumberF1314
This Dell Computer Corporation schematic, drawing number F1314 revision X03 dated 1/30/2004, documents a 5U Riser board designed around the Dobson (NQ80332) CPU platform with a PXH (NQ80000PXH-D, NQ80001) southbridge. The board supports DDR2 400 memory across four DIMM slots and features dual-channel SCSI A and SCSI B interfaces using LSI 1030 controllers operating at U320 speeds. Expansion includes PCI Express x8 and x4 slots, PCI-X 1.0 at 133 MHz, and legacy 32-bit/33 MHz 5V PCI slots with hot plug capability. The board incorporates Dobson Flash NVRAM, a CPLD for spare gates, I2C isolation with a dedicated address chart, and ROMB DIMM support. The riser connects to the planar via 202-pin gold fingers and includes comprehensive power, reset, clock, interrupt, and JTAG block diagrams.
Q: What is the drawing number and revision of this Dell riser board?
A: The drawing number is F1314, revision X03, dated 1/30/2004.
Q: What CPU platform and southbridge are used on this board?
A: The CPU platform is Dobson (NQ80332) and the southbridge is PXH (NQ80000PXH-D, NQ80001).
Q: What type of memory and how many slots are supported?
A: The board supports DDR2 400 memory across four DIMM slots.
Q: What SCSI controllers and interface speed are used?
A: Dual LSI 1030 controllers provide SCSI A and SCSI B interfaces at U320 speed.
Q: What expansion slot types are available?
A: The board includes PCI Express x8 and x4 slots, PCI-X 1.0 at 133 MHz slots, and legacy 32-bit/33 MHz 5V PCI slots with hot plug capability.
BrandDell
Project CodeCorvette 5U Riser
Board NumberM8871, M8938, F1314
RevisionA04-00
Date10/29/2004
CPU PlatformDobson
PCH / SouthbridgeLindenhurst, Tumwater
GPU TypeIOP332, NQ80332
dGPU Chip NumberLSI 1030, 62036A1
EC / KBCCPLD
EC/KBC ProgrammableProgrammables on pages 10 (U16), 14 (U14), and 36 (U31)
RAM TypeDDR2 400
RAM ArchitectureROMB DDR2 DIMM
LAN ICPXH, I6700
WiFi / WLAN ICPXH-D
Card Reader ICLSI 1030
USB Hub ICPXH
Charging ICROMB Battery
Charger ArchitectureROMB BATT CNTRL CKT
Power IC(s)DC2DCs
Thermal SensorINTRUSION/FRU/TEMP SENSOR
Drawing Number167100, 166975, 171598
Document NumberSCHEM,RSR,PE2800,SVF1214
This Dell Corvette 5U Riser motherboard, project code Corvette 5U Riser, is based on the Dobson CPU platform with Lindenhurst and Tumwater southbridge components. The board revision is A04-00, dated 10/29/2004, with board numbers M8871, M8938, and F1314. Memory architecture uses DDR2 400 via a ROMB DDR2 DIMM interface. Graphics processing is handled by an IOP332, NQ80332 GPU, with a discrete LSI 1030, 62036A1 dGPU chip. The system incorporates a CPLD EC/KBC, which is programmable on pages 10 (U16), 14 (U14), and 36 (U31). Networking is provided by PXH and I6700 LAN ICs, with PXH-D for wireless. Storage connectivity includes LSI 1030 for card reader functions, and the charging architecture is managed by a ROMB Battery controller circuit. Power delivery uses DC2DCs, and thermal monitoring is handled by an intrusion/FRU/temperature sensor circuit.
Q: What is the EC/KBC on this motherboard and is it programmable?
A: The EC/KBC is a CPLD. It is programmable, with programming interfaces located on pages 10 (U16), 14 (U14), and 36 (U31).
Q: What memory architecture does this motherboard use?
A: This motherboard uses DDR2 400 memory via a ROMB DDR2 DIMM interface.
Q: What is the charging architecture on this motherboard?
A: The charging architecture is managed by a ROMB Battery controller circuit (ROMB BATT CNTRL CKT).
Q: What are the board numbers for this motherboard?
A: The board numbers are M8871, M8938, and F1314.
BrandDell
ModelPowerEdge 2800
Motherboard ManufacturerDell Inc.
Board Number167100
RevisionA06-00
Date2/23/2005
CPU PlatformDobson
GPU TypeATI Rage XL
EC / KBCTumwater
BIOS / SPI FlashDobson Flash NVRAM
RAM TypeDDR2 400
LAN ICBroadcom BCM5704
SCSI ControllerLSI 1020
CPLDXilinx
CPLD Part NumberW8714
PWA Board NumberM8938
PWA Board NumberM8871
PWA Board NumberT8384
PWA Board NumberGC654
PWA Board NumberDC876
PWA Board NumberHC375
PWB Number166975
PWB Number171598
PWB Number170371
PWB Number171436
PWB Number177371
Drawing NumberABC1234
Schematic NumberF1314
Assembly Drawing167100
PWA Number166975
PWA Number171598
PWA Number170371
PWA Number171436
PWA Number177371
This Dell PowerEdge 2800 server schematic, document F1314 revision A06-00 dated 2/23/2005, details the Corvette 5U Riser project board number 167100. The platform is built around the Dobson CPU architecture with a Lindenhurst southbridge and features an ATI Rage XL graphics controller. Memory architecture consists of DDR2 400 with ROMB DDR2 DIMM support. The system utilizes a Tumwater EC/KBC with programmable devices located at U16 on page 10, U14 on page 14, and U31 on page 36. Storage is handled by dual LSI 1030 and LSI 1020 SCSI controllers with U320 SCSI interfaces. Networking is provided by a Broadcom BCM5704 LAN controller. The design incorporates a Xilinx CPLD with Dell part number W8714. Multiple PWA revisions are documented including M8938, M8871, T8384, GC
  • MSI MS-9573 5U Rev X03_44-PCIEX HPC Schematic.pdf
  • MSI MS-9573 Rev 0A riser_5U Dell PE2800,SV Schematic.pdf
  • MSI MS-9573 Rev 120 Schematic.pdf
  • MSI MS-9573 Rev 140 Schematic.pdf
