Dell Cyborg_TGL-U Rev A00 X01 Schematic
This Wistron Cyborg TGLSC motherboard, revision A00, is built around the Intel Tiger Lake U platform and features a discrete NVIDIA N17S-G5 GPU with GDDR5 VRAM. The system uses two DDR4 SODIMM slots for memory expansion. The embedded controller is a MICROCHIP MEC1515H-D0-I, communicating over the eSPI bus. Audio is handled by a REALTEK ALC3204 codec. The BIOS flash configuration varies by model: CBG-NV uses a 32M SOIC 8 non-RPMC IC, while CBG-L uses a 32M WSON RPMC IC. The charging IC is an ISL9538C. Networking is provided by a Realtek RTL8111HS LAN IC and an M.2 NGFF WLAN module. The card reader is a Realtek RTS5144, and the HDMI level shifter is a PARADE PS8719. A NUVOTON NCT7718W thermal sensor manages fan control. The USB-C subsystem includes a CYPRESS CYPD6127 PD controller and a BURNSIDE-BRIDGE 8010 re-timer.
A: The BIOS flash configuration varies by model. CBG-NV uses a 32M SOIC 8 non-RPMC IC, while CBG-L uses a 32M WSON RPMC IC.
A: Yes, the MICROCHIP MEC1515H-D0-I EC/KBC communicates over the eSPI bus, indicating programmability.
A: The schematic indicates a discrete NVIDIA N17S-G5 GPU with GDDR5 VRAM, but no explicit dGPU to
This Wistron Cyborg-N/V/L 14/15_TGL-U schematic, revision X01, dated 2020-08-20, details the CBG X01 N motherboard platform. The board is built around an Intel Tiger Lake U processor and features a discrete NVIDIA N17S-G5 GPU with GDDR5 VRAM, supporting a Unified Memory Architecture (UMA) configuration. The embedded controller is a Microchip MEC1515H-D0-I, and the audio subsystem is managed by a Realtek ALC3204 codec. BIOS storage is provided by a 32MB SPI flash, with the CBG-NV variant using a 32M SOIC 8 non-RPMC package and the CBG-L variant using a 32M WSON RPMC package. System memory consists of two DDR4 SODIMM slots arranged in dual-channel architecture. The charging circuit is built around an ISL9538C controller, supporting both battery and DC jack input. Networking is handled by a Realtek RTL8111H LAN IC and an NGFF WLAN module with CNVi support. A Realtek RTS5144 card reader, a Parade PS8719B USB 3.2 Gen1 redriver, and a Cypress CYPD6127 USB-C PD controller are also integrated.
A: The CBG-NV variant uses a 32M SOIC 8 non-RPMC package, while the CBG-L variant uses a 32M WSON RPMC package. Both are 32MB SPI flash.
Q: Is the EC/KBC programmable on this motherboard?[/b
| Brand | Cyborg |
| Model | N/V/L 14/15_TGL-U |
| Project Code | Cyborg TGLSC |
| Board Number | A41105 |
| Revision | A00 |
| Date | 2021-01-07 |
| CPU Platform | Intel Tiger Lake U |
| GPU Type | NVIDIA N17S-G5 |
| Graphics Architecture | GDDR5 |
| EC / KBC | MEC1515H-D0-I |
| EC/KBC Package | MICROCHIP |
| EC/KBC Programmable | eSPI Bus |
| Audio Codec | REALTEK ALC3204 |
| BIOS / SPI Flash | 32M SOIC 8 / NON RPMC (CBG-NV); 32M WSON / RPMC (CBG-L) |
| BIOS Flash Capacity | 32M |
| BIOS Flash Package | SOIC 8 (CBG-NV); WSON (CBG-L) |
| Charging IC | ISL9538C |
| RAM Architecture | SODIMM |
| Card Reader IC | Realtek RTS5144 |
| LAN IC | Realtek RTL8111HS |
| WiFi / WLAN IC | M.2 NGFF WLAN |
| HDMI Level Shifter | PARADE PS8719 |
| Thermal Sensor | NUVOTON NCT7718W |
| USB Hub IC | CYPRESS CYPD6127 |
| Power IC(s) | BURNSIDE-BRIDGE 8010 |
| Model | Cyborg-N/V/L 14/15_TGL-U & Watchmen 14N TGL-U |
| Project Code | Cyborg TGL |
| Board Number | CBG X01 N |
| Revision | X01 |
| Date | 2020-08-20 |
| BIOS Flash Exact Model | 32M SOIC 8/ NON RPMC (CBG-NV) |
| BIOS Flash Exact Model | 32M WSON/ RPMC (CBG-L) |
| BIOS Flash Capacity | 32MB |
| Charger Architecture | Batt Conn / DC Jack |
| RAM Type | DDR4 SODIMM |
| RAM Architecture | Channel A / Channel B |
| LAN IC | Realtek RTL8111H |
| WiFi / WLAN IC | NGFF WLAN / CNVi |
| HDMI Level Shifter | HDMI 1.4a |
| Power IC(s) | ISL9538C |
| dGPU Chip Number | N17S-G5 |
| dGPU to UMA Conversion Support | UMA: Unified Memory Architecture |
A41105
Tiger Lake-U
N17S-G5
GDDR5
MEC1515H-D0-I
ALC3204
ISL9538C
RTS5144
RTL8111HS
PS8719
NCT7718W
CYPD6127
CBG X01 N
RTL8111H
ISL9538C
N17S-G5
A41105
Tiger Lake-U
N17S-G5
GDDR5
MEC1515H-D0-I
ALC3204
ISL9538C
RTS5144
RTL8111HS
PS8719
NCT7718W
CYPD6127
CBG X01 N
RTL8111H
ISL9538C
N17S-G5
