Dell Wistron Stradale TGL-H 19876 EVT Schematic
No verifiable technical specifications could be extracted from the provided source text. The content appears to be corrupted or non-decodable binary data, lacking any identifiable motherboard identifiers, component models, or board numbers.
No verifiable FAQ items could be generated from the provided source text.
This Wistron-manufactured Dell XPS Stradale 17" motherboard, project code Stradale MLK, is built on the Tiger Lake-H (TGL-H) platform at EVT revision level. The board supports both UMA-only and DISCRTE OPTIMUS graphics configurations, with the discrete GPU identified as an NVidia GN20-E3/P1. System memory consists of two DDR4 SODIMM slots operating at 3200MHz. The embedded controller is a MEC5107K-D4, and the BIOS SPI flash is a W25Q80DVSNIG with 32MB capacity supporting RPM. Audio processing is handled by an ALC711 codec paired with an ALC1309D amplifier. The charging architecture utilizes CCG6DF controllers, and connectivity includes a WLAN/BT 4.1 SIP module. A Realtek RTS 5243 card reader, ST33HTPH2X32AHD4 TPM, and LIS2DW12 G-sensor are also integrated.
Q: What BIOS flash IC is used on this motherboard?
A: The BIOS SPI flash is a W25Q80DVSNIG with 32MB capacity supporting RPM.
A: The embedded controller is a MEC5107K-D4.
Q: What graphics configurations does this motherboard support?
A: This motherboard supports both UMA-only and DISCRTE OPTIMUS configurations, with the discrete GPU being an NVidia GN20-E3/P1.
A: The motherboard uses two DDR4 SODIMM slots operating at 3200MHz.
| Brand | Dell (XPS) |
| Model | Stradale 17" XPS |
| Project Code | Stradale MLK |
| Board Number | 4PD0JD01B001 (STRADALE MLK 19873) / 4PD0JD01C001 (STRADALE MLK 19876) |
| Revision | EVT |
| Date | Tuesday, August 18, 2020 |
| CPU Platform | Tiger Lake-H (TGL-H) |
| GPU Type | NVidia GFX GN20-E3/P1 |
| Graphics Architecture | DISCRTE OPTIMUS |
| EC / KBC | MEC5107K-D4 |
| Audio Codec | ALC711 |
| Audio AMP | ALC1309D |
| BIOS / SPI Flash | W25Q80DVSNIG |
| BIOS Flash Exact Model | W25Q80DVSNIG |
| BIOS Flash Capacity | 32MB Flash (RPM support) |
| Charging IC | CCG6DF |
| RAM Architecture | SODIMM |
| Card Reader IC | RTS 5243 |
| WiFi / WLAN IC | WLAN / BT 4.1 SIP Module |
| TPM | ST33HTPH2X32AHD4 |
| G-Sensor | LIS2DW12 |
Tiger Lake-H
GFX GN20-E3
GFX GN20-P1
DISCRTE OPTIMUS
MEC5107K-D4
ALC711
ALC1309D
W25Q80DVSNIG
CCG6DF
RTS5243
ST33HTPH2X32AHD4
LIS2DW12
Motion / Position Sensor
Tiger Lake-H
GFX GN20-E3
GFX GN20-P1
DISCRTE OPTIMUS
MEC5107K-D4
ALC711
ALC1309D
W25Q80DVSNIG
CCG6DF
RTS5243
ST33HTPH2X32AHD4
LIS2DW12
