Schematic Dell latitude 3520 - Cyborg -L15 MB TGL 203070-1 Schematic
BrandCyborg
ModelN/V/L 14/15_TGL-U
Motherboard ManufacturerWistron Corporation
Project CodeCyborg TGL
Board NumberA41105
RevisionA00
Date2021-01-07
CPU PlatformIntel Tiger Lake U
GPU TypeNVIDIA N17S-G5
Graphics ArchitectureGDDR5
dGPU Chip NumberN17S-G5
EC / KBCMEC1515H-D0-I
EC/KBC PackageMICROCHIP
Audio CodecREALTEK ALC3204
BIOS / SPI Flash32M SOIC 8 / NON RPMC (CBG-NV); 32M WSON / RPMC (CBG-L)
Charging ICISL9538C
RAM TypeDDR4 SODIMM
RAM ArchitectureChannel A, Channel B
RAM Quantity / Slots2
Card Reader ICRealtek RTS5144
LAN ICRealtek RTL8111H
WiFi / WLAN ICCNVi
HDMI Level ShifterPARADE PS8719
This Wistron Cyborg TGL motherboard, board number A41105 revision A00, is built around the Intel Tiger Lake U platform. The system utilizes a discrete NVIDIA N17S-G5 GPU with GDDR5 memory and supports dual-channel DDR4 SODIMM memory across Channel A and Channel B. The embedded controller is a Microchip MEC1515H-D0-I, and the audio codec is a Realtek ALC3204. The charging IC is an ISL9538C. For BIOS storage, the CBG-NV variant uses a 32M SOIC 8 non-RPMC flash, while the CBG-L variant uses a 32M WSON RPMC flash. Networking is handled by a Realtek RTL8111H LAN IC and CNVi wireless. The HDMI interface uses a Parade PS8719 level shifter, and the card reader is a Realtek RTS5144.
Q: What BIOS flash configurations are used on this motherboard?
A: The CBG-NV variant uses a 32M SOIC 8 non-RPMC flash, while the CBG-L variant uses a 32M WSON RPMC flash.
A: The embedded controller is a Microchip MEC1515H-D0-I.
A: The charging IC is an ISL9538C.
Q: What GPU is used on this motherboard?
A: The discrete GPU is an NVIDIA N17S-G5 with GDDR5 memory.
BrandWistron Corporation
ModelCyborg-N/V/L 14/15_TGL-U
Board NumberCBG X01 N
RevisionX01
Date2020-08-20
BIOS Flash Exact Model32M SOIC 8 / NON RPMC (CBG-NV)
BIOS Flash Capacity32M
BIOS Flash PackageSOIC 8 (CBG-NV)
Compatible BIOS IC Models32M WSON / RPMC (CBG-L)
Charging ICISL9538C
RAM TypeDDR4
RAM ArchitectureSODIMM
LAN ICRealtek RTL8111HS
WiFi / WLAN ICCNVi
The Wistron Cyborg-N/V/L 14/15_TGL-U motherboard, project code Cyborg TGL and board number CBG X01 N revision X01, is built around an Intel Tiger Lake U CPU platform. Graphics are handled by an NVIDIA N17S-G5 GPU with GDDR5 VRAM. The embedded controller is a MICROCHIP MEC1515H-D0-I. Audio is provided by a REALTEK ALC3204 codec. The BIOS SPI flash is a 32M SOIC 8 non-RPMC configuration for CBG-NV variants, with a compatible 32M WSON RPMC option for CBG-L. System memory consists of two DDR4 SODIMM slots. The charging IC is an ISL9538C. Wired networking uses a Realtek RTL8111HS LAN IC, while wireless connectivity supports CNVi. The HDMI level shifter is a PARADE PS8719, and the card reader controller is a Realtek RTS5144.
A: The CBG-NV variant uses a 32M SOIC 8 non-RPMC SPI flash. The CBG-L variant uses a compatible 32M WSON RPMC SPI flash.
A: The embedded controller is a MICROCHIP MEC1515H-D0-I.
A: The motherboard uses two DDR4 SODIMM slots.
ModelCyborg_TGL-H RTX_IO Board
Project CodeQRQY00001063
Board NumberCyborg_IO_BoardSA
RevisionSA
Date2020/07/28
CPU PlatformTGL-H
Card Reader ICRTS5144-GR-GP
USB Hub ICParade PS8719
This Wistron Corporation Cyborg_IO_BoardSA, revision SA, is an I/O board designed for the TGL-H RTX platform under project code QRQY00001063, dated 2020/07/28. The board integrates a Realtek RTS5144-GR-GP card reader IC supporting a standard SD card slot via USB 2.0, and a Parade PS8719 USB 3.0 redriver for 5Gbps operation. The block diagram also indicates a USB 3.2 Gen1 Type-A port and a fingerprint reader connection. The schematic includes detailed layout notes for critical signals such as SDREFG, RREF, and power rails 3D3V_CARD_S0 and V18.
Q: What is the project code and board number for this I/O board?
A: The project code is QRQY00001063 and the board number is Cyborg_IO_BoardSA, revision SA.
Q: What card reader IC is used on this board?
A: The card reader IC is a Realtek RTS5144-GR-GP.
Q: What USB redriver is present on this board?
A: A Parade PS8719 USB 3.0 redriver is used for 5Gbps operation.
  • Cyborg_TGL REVA00_.pdf
  • Cyborg_TGL REVX01_.pdf
  • QRQY00001063_.pdf
