dell-inspiron-3520 caruso15hr_reva00 schematic
dell-inspiron-3520=1=caruso15hr_reva00.pdf
This Wistron Enrico/Caruso 15 HRX01 motherboard, project code 91.4IP01.001 and board number 48.4IP16.0S revision 10316-1, is built on the Intel Sandy Bridge CPU platform with an Intel Cougar Point PCH. The system management is handled by a NUVOTON NPCE795P EC/KBC. Audio processing is provided by an IDT 92HD87B1 codec. The board features a 4MB Flash ROM for BIOS/SPI storage. Power management is handled by a BQ24707 charger IC and multiple DC/DC converters including ISL95831HRTZ, TPS51216RUKR, TPS51123RGER, TPS51218, TPS51311RGTR, and TPS51461. Memory configuration supports two DDRIII 1066/1333 DIMM slots in dual-channel architecture. Connectivity includes a Realtek RTS5138 card reader, Realtek RTL8105E and RTL8111E-VB LAN ICs, and an 802.11b/g/n BT V3.0+HS Mini-Card wireless module.
A: The motherboard uses a NUVOTON NPCE795P EC/KBC.
A: The board uses a 4MB Flash ROM for BIOS/SPI storage.
A: The charging IC is a BQ24707.
A: The audio codec is an IDT 92HD87B1.
| Model | Enrico/Caruso 15 HRX01 |
| Project Code | 91.4IP01.001 |
| Board Number | 48.4IP16.0S |
| Revision | 10316-1 |
| Date | Thursday, June 02, 2011 |
| CPU Platform | Intel Sandy Bridge |
| EC / KBC | NUVOTON NPCE795P |
| Audio Codec | IDT 92HD87B1 |
| BIOS / SPI Flash | 4MB Flash ROM |
| Charging IC | BQ24707 |
| Power IC(s) | ISL95831HRTZ, TPS51216RUKR, TPS51123RGER, TPS51218, TPS51311RGTR, TPS51461 |
| RAM Type | DDRIII 1066/1333 |
| Card Reader IC | Realtek RTS5138 |
| LAN IC | Realtek RTL8105E, Realtek RTL8111E-VB |
| WiFi / WLAN IC | 802.11b/g/n BT V3.0+HS Mini-Card |
91.4IP01.001
48.4IP16.0S
Sandy Bridge
NPCE795P
92HD87B1
BQ24707
ISL95831HRTZ
TPS51123RGER
TPS51216RUKR
TPS51218
TPS51311RGTR
TPS51461
RTS5138
RTL8105E
RTL8111E-VB
n BT V3.0
91.4IP01.001
48.4IP16.0S
Sandy Bridge
NPCE795P
92HD87B1
BQ24707
ISL95831HRTZ
TPS51123RGER
TPS51216RUKR
TPS51218
TPS51311RGTR
TPS51461
RTS5138
RTL8105E
RTL8111E-VB
n BT V3.0
