Dell Inspiron 7506 Wistron Hellcat 15 UP TGL DG1 19B31-1 Schematic
This Wistron Corporation Hellcat 15 UP TGL DG1 Sensor Board, project code 4PD0JY010001, uses PCB P/N 19B31-1 revision -1, dated 2020-07-09, with document number X01. The board integrates an LSM6DS3USTR gyroscope and G-sensor alongside an LIS2MDLTR e-compass for motion and orientation sensing. A dedicated sensor connector provides interface access for SENSOR_I2C_SCL, SENSOR_I2C_SDA, and GSEN_INT1 signals. The design is a compact sensor sub-board supporting the Hellcat 15 platform.
Q: What are the main sensor ICs on this board?
A: The board uses an LSM6DS3USTR gyroscope + G sensor and an LIS2MDLTR e-compass.
Q: What is the board number and revision?
A: The board number is 19B31-1, revision -1.
Q: What is the project code for this sensor board?
A: The project code is 4PD0JY010001.
The Wistron Hellcat 15'' Upsell TGL-1 motherboard, project code 4PD0HC010001 and board number 19828 revision X00, is built around the Intel Tiger Lake-U platform with LPDDR4X memory architecture. Graphics are handled by an Intel DG1 25W GPU in a DISCRTE OPTIMUS configuration. The system firmware resides on a Quad Read Flash ROM with a combined capacity of 16 + 8 MB. Embedded controller functions are managed by a Microchip MEC1515. Audio is provided by a Realtek ALC3254-VA327 codec. The charging solution incorporates a CCG6SF controller. Memory is configured as two 8GB 12MD x32 Type-3 LPDDR4X modules at 3200 MT/s across Channel A and Channel B. Thermal monitoring is handled by a Nuvoton NCT7718W sensor. Peripheral connectivity includes a Realtek RTS5144 card reader, a Parade PS8719B USB 3.1 Gen1 re-driver, and a Parade PS8409AQFN DisplayPort to HDMI converter. Wireless connectivity is supported via an M.2 1216 Harrison peak2 WLAN SIP module.
A: The system uses a Quad Read Flash ROM with a combined capacity of 16 + 8 MB.
A: The embedded controller is a Microchip MEC1515.
Q: What is the graphics configuration of this motherboard?
A: The motherboard features an Intel DG1 25W GPU in a DISCRTE OPTIMUS architecture.
A: The motherboard uses LPDDR4X memory across Channel A and Channel B, populated with two 8GB 12MD x32 Type-3 modules at 3200 MT/s.
A: The charging controller is a CCG6SF.
| Model | Hellcat 15 UP TGL DG1 Sensor Board |
| Project Code | 4PD0JY010001 |
| Board Number | 19B31-1 |
| Revision | -1 |
| Date | 2020-07-09 |
| Document Number | X01 |
| Gyroscope + G sensor | LSM6DS3USTR |
| E-compass | LIS2MDLTR |
| Model | Hellcat 15'' Upsell TGL-1 |
| Project Code | 4PD0HC010001 |
| Board Number | 19828 |
| Revision | X00 |
| Date | Monday, August 03, 2020 |
| CPU Platform | Tiger Lake - U/LPPDR4X |
| GPU Type | Intel DG1 25W |
| Graphics Architecture | DISCRTE OPTIMUS |
| EC / KBC | MEC1515 |
| EC/KBC Package | MICROCHIP |
| Audio Codec | Realtek ALC3254-VA327 |
| BIOS / SPI Flash | Quad Read Flash ROM |
| BIOS Flash Capacity | 16 + 8 MB |
| Charging IC | CCG6SF |
| RAM Type | LPDDR4X |
| RAM Architecture | LPDDR4/4x Channel A / LPDDR4/4x Channel B |
| RAM Quantity / Slots | 12MD x32 Type-3: 3200 8GB x2 |
| Thermal Sensor | NUVOTON NCT7718W |
| Card Reader IC | Realtek RTS5144 |
| USB Hub IC | PARADE PS8719B |
| LAN IC | WLAN SIP |
| WiFi / WLAN IC | M.2 1216 Harrison peak2 |
| HDMI Level Shifter | Parade PS8409AQFN |
4PD0JY010001
19B31-1
4PD0HC010001
19828
LPPDR4X
Tiger Lake-U
DG1 25W
DISCRTE OPTIMUS
MEC1515
ALC3254-VA327
CCG6SF
LPDDR4X
NCT7718W
RTS5144
PS8719B
PS8409AQFN
4PD0JY010001
19B31-1
4PD0HC010001
19828
LPPDR4X
Tiger Lake-U
DG1 25W
DISCRTE OPTIMUS
MEC1515
ALC3254-VA327
CCG6SF
LPDDR4X
NCT7718W
RTS5144
PS8719B
PS8409AQFN
