asus aio et2410 la-7521p_rev0.2_la-7522p_rev0.1 schematic
asus aio et2410=1=la-7521p_rev0.2_la-7522p_rev0.1.pdf
This Compal PCA70 LA-7521P M/B revision 0.2 schematic, dated April 12, 2011, details a motherboard built around the Intel Sandy Bridge processor and Intel Cougar Point H61 PCH. The platform supports dual-channel DDRIII memory via two 204-pin SO-DIMM slots. Graphics are handled by a discrete NV N12P-GV or N12P-GS VGA chip with dedicated DDR3 VRAM. The embedded controller is an ENE KB930C, and the audio codec is an ALC663. Power management is distributed across multiple ICs including the RT8205EGQW charging IC, TPS51212DSCR, APL5610CI, and NCP5911MNTBG. The system includes an RTL8111E LAN IC, an ASM1042 USB 3.0 controller, a JMB385 card reader controller, and an RTD2482D HDMI level shifter. SPI ROM is used for BIOS storage.
A: The embedded controller is an ENE KB930C.
A: The charging IC is an RT8205EGQW.
A: The LAN IC is an RTL8111E.
A: The audio codec is an ALC663.
| Model | PCA70 LA-7521P M/B |
| Project Code | PCA70/61 |
| Board Number | LA-7521P |
| Revision | 0.2 |
| Date | Tuesday, April 12, 2011 |
| CPU Platform | Intel Processor (Sandy Bridge) |
| PCH / Southbridge | Intel PCH Cougar Point H61 |
| GPU Type | NV N12P-GV / NV N12P-GS |
| Graphics Architecture | VGA Chip NV N12P-GV / NV N12P-GS (default) |
| EC / KBC | ENE KB930C |
| Audio Codec | ALC663 |
| Charging IC | RT8205EGQW |
| Power IC(s) | TPS51212DSCR, APL5610CI, NCP5911MNTBG, AP4800BGM, APL5930KAI, TPS54331DR, RT8205EGQW |
| RAM Quantity / Slots | 204pin DDRIII-SO-DIMM X2 |
| Card Reader IC | JMB385 |
| USB Hub IC | ASM1042 |
| LAN IC | RTL8111E |
| WiFi / WLAN IC | PCIe Mini Card WLAN |
| HDMI Level Shifter | RTD2482D |
PCA70
LA-7521P
Sandy Bridge
H61
N12P-GS
N12P-GV
N12P-NV
KB930C
ALC663
RT8205EGQW
AP4800BGM
APL5610CI
APL5930KAI
NCP5911MNTBG
RT8205EGQW
TPS51212DSCR
TPS54331DR
JMB385
ASM1042)
RTL8111E
RTD2482D
PCA70
LA-7521P
Sandy Bridge
H61
N12P-GS
N12P-GV
N12P-NV
KB930C
ALC663
RT8205EGQW
AP4800BGM
APL5610CI
APL5930KAI
NCP5911MNTBG
RT8205EGQW
TPS51212DSCR
TPS54331DR
JMB385
ASM1042)
RTL8111E
RTD2482D
