Lenovo AIO 520-24ICB LA-F901P Rev 1.0 Schematic
The Compal LA-F901P M/B revision 0.1 is an Intel Coffee Lake-S platform motherboard with DDR4 memory support and an AMD GPU (M17) graphics architecture. The board is built around the Intel B360 PCH and features an LGA1151 CPU socket. The system EC is an NCT6685D3W, with its firmware stored on a W25X20CLSNIG (128KB) SPI flash. The main BIOS is a W25Q64FVSSIQ 16MB SPI ROM. Audio is handled by a Realtek ALC274 codec, while networking is provided by a Realtek RTL8111G LAN IC. The board supports DDR4-SO-DIMM memory across two banks (Channel A and Channel B). A Realtek RTS5170 card reader is integrated, and HDMI conversion is managed by an RTD2136N converter or RTD2506S-CG scalar.
A: The main BIOS SPI ROM is a W25Q64FVSSIQ with 16MB capacity.
A: Yes, the EC firmware is stored on a W25X20CLSNIG (128KB) SPI flash, indicating programmability.
A: The board uses DDR4-SO-DIMM modules across two banks: BANK 0 and BANK 1 for both Channel A and Channel B.
Q: What graphics configuration does this motherboard support?
A: The platform includes an AMD GPU (M17) for discrete graphics processing.
| Model | LA-F901P |
| Board Number | LA-F901P M/B |
| Revision | 0.1 |
| Date | Tuesday, March 13, 2018 |
| CPU Platform | Intel Coffee Lake-S with DDR4 + CNP + AMD GPU (M17) |
| CPU Socket | LGA1151 |
| PCH / Southbridge | B360 |
| GPU Type | AMD GPU |
| Graphics Architecture | AMD GPU (M17) |
| EC / KBC | NCT6685D3W |
| EC/KBC Programmable | EC FW W25X20CLSNIG (128KB) SPI |
| Audio Codec | Realtek ALC274 |
| BIOS / SPI Flash | W25Q64FVSSIQ (16MB) SPI ROM |
| BIOS Flash Exact Model | W25Q64FVSSIQ |
| BIOS Flash Capacity | 16MB |
| EC Flash / ROM | W25X20CLSNIG (128KB) SPI |
| Charging IC | TI TAS5766MRMTR (Option) |
| RAM Type | DDR4-SO-DIMM |
| RAM Architecture | DDR4-SO-DIMM BANK 0, 1 Channel A / BANK 0, 1 Channel B |
| Card Reader IC | Realtek RTS5170 |
| LAN IC | Realtek RTL8111G |
| WiFi / WLAN IC | WLAN/BT DM |
| HDMI Level Shifter | RTD2136N / Scalar RTD2506S-CG |
LA-F901P M/B
Coffee Lake-S
LGA1151
B360
AMD GPU
AMD GPU (M17)
NCT6685D3W
FW W25X20CLSNIG SPI
ALC274
W25Q64FVSSIQ
W25X20CLSNIG SPI
TAS5766MRMTR
RTS5170
RTL8111G
RTD2136N
SCALAR RTD2506S-CG
LA-F901P M/B
Coffee Lake-S
LGA1151
B360
AMD GPU
AMD GPU (M17)
NCT6685D3W
FW W25X20CLSNIG SPI
ALC274
W25Q64FVSSIQ
W25X20CLSNIG SPI
TAS5766MRMTR
RTS5170
RTL8111G
RTD2136N
SCALAR RTD2506S-CG
