Lenovo AIO 3-22ADA6 LA-K901P Rev 1.0 Schematic
BrandCompal
ModelLS-K882P
Board NumberLS-E882P
Revision0.1
Date2020-12-24
Document NumberLS-E882P
PCB NumberZZZPCB LS-K882P DA4002ZR010
This Compal LS-K882P Power Button Board schematic, document number LS-E882P revision 0.1, dated 2020-12-24, is a sub-board designed for power button functionality. The PCB is identified as ZZZPCB LS-K882P DA4002ZR010. The board includes a power button switch (SW1), a white LED indicator (LED1, model T1361DND-30P00215), and an ESD protection diode (D1, model PESD5V0U2BT in SOT-23-3 package). Power input is provided via +5VALW_S5 rail. The board is classified as Compal Secret Data and is a proprietary design of Compal Electronics, Inc.
Q: What is the board number and revision of this power button board?
A: The board number is LS-E882P, revision 0.1.
Q: What is the PCB identifier for this board?
A: The PCB identifier is ZZZPCB LS-K882P DA4002ZR010.
Q: What type of LED is used for the power indicator?
A: The power indicator LED is model T1361DND-30P00215, a cold white LED.
BrandCompal
Board NumberLA-K901P
Revision0.1
DateMonday, January 25, 2021
CPU PlatformAMD FP5 with DDR4
EC / KBCNCT6686DL
EC Flash / ROMW25X20CLSNIG (2Mb)
BIOS / SPI FlashW25Q128FWSIQ (16MB)
Audio CodecRealtek ALC233
LAN ICRealtek RTL8111G/H
Card Reader ICRealtek RTS5140
USB Hub ICGL852
RAM TypeDDR4-SO-DIMM
RAM ArchitectureBANK 0, 1
Charging ICTI 3110
WiFi / WLAN ICWLAN/BT
HDMI Level ShifterRTD2136Ne
GPU TypeAMD APU ([URL="https://dr-bios.com/components/graphics-models/fp5-type2/"]FP5 Type2)[/URL]
Graphics ArchitectureLidless BGA 0.64mm ball pitch 1140 pins 25mm x 35mm 15W 2400 MHz Max
This Compal LA-K901P revision 0.1 motherboard is built around an AMD FP5 APU with DDR4 memory support, utilizing two DDR4-SO-DIMM banks. The platform integrates an AMD APU (FP5 Type2) with a lidless BGA package featuring a 0.64mm ball pitch, 1140 pins, and dimensions of 25mm x 35mm, rated at 15W with a maximum frequency of 2400 MHz. The system is managed by an Nuvoton NCT6686DL EC/KBC, which is supported by a dedicated W25X20CLSNIG 2Mb EC flash ROM. The main BIOS SPI flash is a W25Q128FWSIQ 16MB IC. Audio processing is handled by a Realtek ALC233 codec, while networking is provided by a Realtek RTL8111G/H LAN controller. A Realtek RTS5140 card reader and a GL852 USB 2.0 hub are also present. The HDMI output is managed by a RTD2136Ne level shifter, and the charging circuit utilizes a TI 3110 IC.
A: The main BIOS SPI flash is a W25Q128FWSIQ with a capacity of 16MB.
Q: What EC/KBC and EC flash are used on this motherboard?
A: The EC/KBC is an Nuvoton NCT6686DL, and its dedicated EC flash is a W25X20CLSNIG with a capacity of 2Mb.
A: The motherboard supports DDR4-SO-DIMM memory across two banks, labeled BANK 0 and BANK 1.
Q: What is the graphics architecture of this motherboard?
A: The graphics are integrated into the AMD APU (FP5 Type2), which uses a lidless BGA package with a 0.64mm ball pitch, 1140 pins, dimensions of 25mm x 35mm, a 15W TDP, and a maximum frequency of 2400 MHz.
  • Lenovo AIO 3-22ADA6 LA-K901P POWER Schematic.pdf
  • Lenovo AIO 3-22ADA6 LA-K901P Rev 1.0 Schematic.pdf
