Schematic acer iconia tablet a100 (compal la-7251p) e3fed rev 1.0.pdf schematic
acer iconia tablet a100 (compal la-7251p) e3fed rev 1.0.pdf 1
BrandCompal
Motherboard ManufacturerCompal Electronics, Inc.
Project CodePBJ30
Board NumberLA-7251P
Revision1.0
Date2011-04-12
CPU PlatformNVIDIA Tegra250 (T20)
EC / KBCENE KB930
Audio CodecALC105
Audio AmplifierWolfson WM8903
Charging ICBQ24725
PMICTPS658621
RAM TypeLPDDR POP
RAM Architecture512MB/1GB
Thermal SensorNCT1008
WiFi / WLAN ICAzureWave AW-NH611
HDMI Level ShifterSN75LVDS83B
USB Hub ICSMSC USB3315
Card Reader ICPS8122
GPU Type[URL="https://dr-bios.com/components/graphics-models/nvidia-tegra250-t20/"]NVIDIA Tegra250 (T20)[/URL]
Graphics ArchitectureNVIDIA Tegra250 (T20)
Touch-key ControllerENE 3534
G-SensorKXTF9-4100
Gyro SensorInvensense MPU-3050
E-CompassAKM8975
Light SensorAL3000
GPS ICBCM4751
Audio Codec (Digital MEMS)Fortemedia FM2018
This Compal LA-7251P (PBJ30) reference design is built around the NVIDIA Tegra250 (T20) SoC, integrating both CPU and GPU on a single FCBGA package. The platform utilizes LPDDR POP memory configurable to 512MB or 1GB. System management is handled by an ENE KB930 EC/KBC, while power delivery is managed by a TPS658621 PMIC and BQ24725 charging IC. Audio processing is split between an ALC105 codec and a Wolfson WM8903 amplifier. Connectivity includes an AzureWave AW-NH611 WLAN/BT module, SMSC USB3315 ULPI PHY, and PS8122 signal switch for docking. The board features a comprehensive sensor suite including KXTF9-4100 G-sensor, MPU-3050 gyro, AKM8975 e-compass, and AL3000 light sensor. Display output is provided via an SN75LVDS83B LVDS bridge, and thermal monitoring is handled by an NCT1008 sensor.
A: The EC/KBC is an ENE KB930.
Q: What is the charging IC and PMIC configuration?
A: The charging IC is a BQ24725, and the PMIC is a TPS658621.
Q: What memory architecture does this platform use?
A: The platform uses LPDDR POP memory, configurable to 512MB or 1GB.
Q: What audio components are present?
A: Audio is handled by an ALC105 codec and a Wolfson WM8903 audio amplifier.
  • Acer Iconia Tablet A100=1=(Compal LA-7251P)_e3fed_Rev 1.0.pdf.zip
