acer iconia tab a210 v0jet_compal la-8981p_rev1.0 schematic
acer iconia tab a210=1=v0jet_compal la-8981p_rev1.0.pdf
This Compal V0JET (A210)_ LA8981P motherboard, revision 1.0, is built around the Nvidia T30L platform with 1GB of DDR3L memory. The system integrates a WM8903 audio codec and APA2010 audio amplifier for sound output. Power management is handled by a TPS6591104 PMU and a TPS62361 charging IC. Connectivity includes an AzureWave AW-NH660 WiFi/BT combo module and a Broadcom BCM47511 GPS receiver. Sensor support is provided by a KXTF9-4100 G-sensor and MPU-3050 gyroscope. Display output is driven through an SN75LVDS83 LVDS transmitter. Storage is managed via eMMC, with Hynix DDR X76418BOL02 X76-H@ and Samsung DDR X76418BOL01 X76-S@ memory components identified. Thermal monitoring is handled by an NCT72 sensor, and an AT24C02C EEPROM is present for configuration data.
Q: What is the CPU platform used on this motherboard?
A: The motherboard uses the Nvidia T30L platform.
A: The audio codec is a WM8903 and the audio amplifier is an APA2010.
Q: What power management ICs are present?
A: The system uses a TPS6591104 PMU and a TPS62361 charging IC.
Q: What eMMC memory components are identified?
A: The eMMC components are Hynix DDR X76418BOL02 X76-H@ and Samsung DDR X76418BOL01 X76-S@.
| Model | V0JET (A210)_ LA8981P |
| Project Code | V0JET(A210)-LA8981P |
| Board Number | LA8981P |
| Date | 2012-06-11 |
| CPU Platform | Nvidia T30L |
| RAM Type | DDR3L |
| RAM Architecture | 1GB |
| Audio Codec | WM8903 |
| Audio Amplifier | APA2010 |
| Charging IC | TPS62361 |
| Power IC(s) | TPS6591104 |
| Thermal Sensor | NCT72 |
| WiFi / WLAN IC | AzureWave AW-NH660 |
| GPS IC | Broadcom BCM47511 |
| G-Sensor | KXTF9-4100 |
| Gyro Sensor | MPU-3050 |
| LVDS Transmitter | SN75LVDS83 |
| EEPROM | AT24C02C |
| eMMC | Hynix DDR X76418BOL02 X76-H@ / Samsung DDR X76418BOL01 X76-S@ |
A210
LA8981P
V0JET
LA8981P
T30L
DDR3L
WM8903
APA2010
TPS62361
TPS6591104
NCT72
AzureWave AW-NH660
KXTF9-4100
Motion / Position Sensor
AT24C02C
A210
LA8981P
V0JET
LA8981P
T30L
DDR3L
WM8903
APA2010
TPS62361
TPS6591104
NCT72
AzureWave AW-NH660
KXTF9-4100
AT24C02C
