acer iconia tab a510 qaja0 la-8511p_rev2.0 schematic
acer iconia tab a510=1=qaja0 la-8511p_rev2.0.pdf
This Compal Picasso II/M38 reference design, documented under board number QAJA0-LA-8511PZZZ0PCBMBZZZ0PCBMB revision 2.0 dated 2012/06/20, is built around the Nvidia T30S platform. The system architecture integrates LPDDR2 memory configurable at 512MB or 1GB. Audio processing is handled by an Audience eS305 processor paired with a WM8903 audio codec and an APA2010 audio amplifier. Wireless connectivity is provided by an AzureWave AW-AH662 module, while GPS functionality is managed by a Broadcom BCM47511 IC. Power management is controlled by a TPS659110 PMIC. The board includes a KXTF9-4100 G-sensor, MPU-3050 gyro sensor, STK2203 light sensor, and AKM8975 E-compass for motion and environmental sensing. Display output is facilitated by a V105A LVDS transmitter.
Q: What is the board number for this Compal Picasso II/M38 platform?
A: The board number is QAJA0-LA-8511PZZZ0PCBMBZZZ0PCBMB.
Q: What CPU platform is used on this motherboard?
A: The CPU platform is the Nvidia T30S.
Q: What type of memory is supported on this board?
A: The board supports LPDDR2 memory, configurable at 512MB or 1GB.
Q: What audio codec and amplifier are used on this motherboard?
A: The audio codec is a WM8903 and the audio amplifier is an APA2010.
| Project Code | Picasso II/M38 |
| Board Number | QAJA0-LA-8511PZZZ0PCBMBZZZ0PCBMB |
| Revision | 2.0 |
| Date | 2012/06/20 |
| CPU Platform | Nvidia T30S |
| GPU Type | Nvidia T30S |
| RAM Type | LPDDR2 |
| RAM Architecture | 512MB/1GB |
| Audio Codec | WM8903 |
| Audio Amplifier | APA2010 |
| WiFi / WLAN IC | AzureWave AW-AH662 |
| GPS IC | Broadcom BCM47511 |
| PMIC | TPS659110 |
| G-Sensor | KXTF9-4100 |
| Gyro Sensor | MPU-3050 |
| Light Sensor | STK2203 |
| E-Compass | AKM8975 |
| LVDS Transmitter | V105A |
| Audio Processor | Audience eS305 |
