Acer A315-52 LA-K701P Schematic
The Compal LA-K701P Rev 1C schematic, dated November 10, 2020, details a motherboard built around the Intel Jasper Lake platform with a Jasper Lake PCH JSL45. The board utilizes dual-channel DDR4 memory via two 260-pin SO-DIMM slots. The embedded controller is an ENE KB9052, and the audio subsystem is managed by an ALC255 codec. System firmware is stored on a 128Mb SPI ROM. Wired networking is provided by a Realtek 8111H GbE controller. The board features a PS8409 HDMI repeater for display output and an SLGC55544 USB charger IC for power management.
Q: What EC/KBC is used on the Compal LA-K701P?
A: The embedded controller is an ENE KB9052.
Q: What is the BIOS flash capacity on this motherboard?
A: The SPI ROM is 128Mb.
Q: What is the memory architecture of the LA-K701P?
A: It supports dual-channel DDR4 memory via two 260-pin SO-DIMM slots.
Q: What LAN controller is used on this board?
A: The wired LAN controller is a Realtek 8111H.
| Model | LA-K701P |
| Project Code | LA-K701P |
| Board Number | LA-K701P |
| Revision | 1C |
| Date | 2020.11.10 |
| CPU Platform | Intel Jasper Lake |
| PCH / Southbridge | Jasper lake PCH JSL45 |
| EC / KBC | ENE KB9052 |
| Audio Codec | ALC255 |
| BIOS / SPI Flash | SPI ROM 128Mb |
| RAM Quantity / Slots | 260pin DDR4-SO-DIMM X1, 260pin DDR4-SO-DIMM X1 |
| LAN IC | Realtek 8111H |
| HDMI Level Shifter | PS8409 |
| Charging IC | SLGC55544 |
