Schematic Acer Aspire 3 A315-56 Compal LA-J801P LA-H801P FH5LI Schematic
Acer Aspire 3 A315-56 Compal LA-J801P FH5LI Schematic
BrandCompal
ModelFH5LI M/B LA-H801P
Board NumberLA-H801P
Revision1.0
Date2019.10.30
CPU PlatformIntel Ice Lake U
EC / KBCENE KB9052
Audio CodecALC255
BIOS / SPI FlashSPI ROM 128Mb
RAM TypeDDR4
RAM ArchitectureDDR4-SO-DIMM X1 / DDR4-ON BOARD 4G 8Gbx16 Interleaved Memory
RAM Quantity / SlotsDual Channel
LAN ICRealtek 8111H
Card Reader ICRTS5140
This Compal FH5LI M/B LA-H801P schematic, revision 1.0 dated 2019.10.30, documents a motherboard built around the Intel Ice Lake U platform with a 15W TDP processor. The system memory architecture supports both a single DDR4 SO-DIMM slot and onboard DDR4 memory configured as 4G or 8Gbx16 in an interleaved dual-channel arrangement. The embedded controller is an ENE KB9052, and the audio subsystem is handled by a Realtek ALC255 High Definition Audio Codec. The BIOS is stored on a 128Mb SPI ROM. Wired networking is provided by a Realtek 8111H Gigabit Ethernet controller, and a Realtek RTS5140 card reader is integrated for SD card support.
A: The embedded controller is an ENE KB9052.
A: The BIOS is stored on a 128Mb SPI ROM.
A: The motherboard supports dual-channel DDR4 memory via one DDR4 SO-DIMM slot and onboard 4G or 8Gbx16 interleaved memory.
A: The wired LAN controller is a Realtek 8111H.
  • Acer Aspire 3 A315-56 Compal LA-J801P FH5LI Schematic.pdf
