Acer A315 Quanta Z8G DA0Z8GMB8D0 Rev 1A Schematic
The Quanta Z8G project is a motherboard designed around the Intel Gemini Lake (Broxton-P) platform with an integrated PCH. The system memory architecture supports dual-channel DDR4 at up to 2400 MHz via two SO-DIMM slots. The embedded controller is an IT8987, and the audio subsystem is handled by an ALC255 codec. The BIOS is stored on an 8M SPI ROM. Power management is managed by a combination of ICs including the RT3601EAGQW, RT8231BGQW, G5335QT2U, and RT6256BGQUF, while battery charging is controlled by a BQ24780SRUYR. Networking is provided by a Realtek RTL8411B-CG 10/100/1000 Ethernet controller. The board also integrates an NPCT650 TPM module and multiple card reader ICs including the G5719CTB1U, M5671RE1U, and G9661MF11U.
Q: What EC/KBC is used on this Quanta Z8G motherboard?
A: The embedded controller is an IT8987.
Q: What is the BIOS flash configuration for this board?
A: The BIOS is stored on an 8M SPI ROM.
A: The battery charger IC is a BQ24780SRUYR.
Q: What memory architecture does this board support?
A: The board supports dual-channel DDR4 memory at up to 2400 MHz via two SO-DIMM slots.
| Project Code | Z8G |
| Date | Tuesday, December 26, 2017 |
| CPU Platform | Gemini Lake - 6W (BROXTON-P) |
| PCH / Southbridge | Integrated PCH |
| EC / KBC | IT8987 |
| Audio Codec | ALC255 |
| BIOS / SPI Flash | SPI ROM 8M |
| Charging IC | BQ24780SRUYR |
| Power IC(s) | RT3601EAGQW, RT8231BGQW, G5335QT2U, RT6256BGQUF |
| RAM Architecture | Dual Channel DDR4 2400 MHz MAX |
| RAM Quantity / Slots | SO-DIMM1, SO-DIMM2 |
| LAN IC | RTL8411B-CG |
| Card Reader IC | G5719CTB1U, M5671RE1U, G9661MF11U |
| TPM | NPCT650 |
Z8G
Gemini Lake
IT8987
ALC255
BQ24780SRUYR
G5335QT2U
RT3601EAGQW
RT6256BGQUF
RT8231BGQW
RTL8411B-CG
G5719CTB1U
G9661MF11U
M5671RE1U
NPCT650
Z8G
Gemini Lake
IT8987
ALC255
BQ24780SRUYR
G5335QT2U
RT3601EAGQW
RT6256BGQUF
RT8231BGQW
RTL8411B-CG
G5719CTB1U
G9661MF11U
M5671RE1U
NPCT650
