acer a315 quanta z8g da0z8gmb8d0 rev 1a
The Quanta Z8G project, documented under number 1A135 and dated December 26, 2017, is built on the Intel Gemini Lake (BROXTON-P) platform with an integrated PCH. The system memory architecture supports dual-channel DDR4 at a maximum frequency of 2400 MHz, utilizing two SO-DIMM slots. The embedded controller is an IT8987, and the audio subsystem is managed by an ALC255 codec. The primary BIOS storage is an 8M SPI ROM. Power management is handled by a BQ24780SRUYR battery charger and multiple voltage regulators including the RT3601EAGQW, RT8231BGQW, G5335QT2U, and RT6256BGQUF. Wired networking is provided by an RTL8411B-CG 10/100/1000 controller, while wireless connectivity is supported via an M.2 NGFF WLAN+BT module. The system also integrates an NPCT650 TPM, an RTS5765DL card reader, and multiple USB hub controllers.
Q: What is the board project code and document number for this motherboard?
A: The project code is Z8G, and the document number is 1A135, from Quanta Computer Inc.
A: The embedded controller is an IT8987.
A: The BIOS is stored on an 8M SPI ROM.
Q: What is the charging IC and power management architecture?
A: The battery charger is a BQ24780SRUYR, with power regulation provided by RT3601EAGQW, RT8231BGQW, G5335QT2U, and RT6256BGQUF.
Q: What memory architecture does this board support?
A: It supports dual-channel DDR4 at up to 2400 MHz via two SO-DIMM slots.
| Project | Z8G |
| Document Number | 1A135 |
| Date | Tuesday, December 26, 2017 |
| CPU Platform | Gemini Lake - 6W (BROXTON-P) |
| PCH / Southbridge | Integrated PCH |
| EC / KBC | IT8987 |
| Audio Codec | ALC255 |
| BIOS / SPI Flash | SPI ROM 8M |
| Charging IC | BQ24780SRUYR |
| Power IC(s) | RT3601EAGQW, RT8231BGQW, G5335QT2U, RT6256BGQUF |
| RAM Architecture | Dual Channel DDR4 2400 MHz MAX |
| RAM Quantity / Slots | SO-DIMM1, SO-DIMM2 |
| LAN IC | RTL8411B-CG |
| Card Reader IC | RTS5765DL |
| TPM | NPCT650 |
| USB Hub IC | G5719CTB1U, M5671RE1U, G9661MF11U |
| WiFi / WLAN IC | M.2 NGFF WLAN+BT |
| HDMI Level Shifter | G5719CTB1U |
Gemini Lake
IT8987
ALC255
BQ24780SRUYR
G5335QT2U
RT3601EAGQW
RT6256BGQUF
RT8231BGQW
RTL8411B-CG
RTS5765DL
NPCT650
G5719CTB1U
G9661MF11U
M5671RE1U
G5719CTB1U
Gemini Lake
IT8987
ALC255
BQ24780SRUYR
G5335QT2U
RT3601EAGQW
RT6256BGQUF
RT8231BGQW
RTL8411B-CG
RTS5765DL
NPCT650
G5719CTB1U
G9661MF11U
M5671RE1U
G5719CTB1U
