toshiba_satellite_p505_qosmio_x500 quanta_tz1_da0tz1mb8d0_tz1h_tz1s_tz1v schematic
toshiba_satellite_p505_qosmio_x500=1=quanta_tz1_da0tz1mb8d0_tz1h_tz1s_tz1v.pdf
This Quanta TZ1C motherboard schematic, dated May 27, 2009, documents a platform supporting Arrandale (UMA+VGA) or Clarksfield (VGA) processors paired with an Ibex Peak-M PCH. The system utilizes dual-channel DDR III memory across two DDRIII-SODIMM slots. Power management is handled by an ISL6251A charger, ISL6237 system regulator, ISL62882 CPU core VR, ISL62881 VAXG VR, UP6111AQDD, and TPS51116 DDR VR. The embedded controller is a WPCE8763L, with an alternate WPC8769L(O) option. Audio is provided by a CX20583 codec, and networking by an Atheros LAN controller. The schematic also includes a card reader/1394 controller and an HDMI level shifter.
Q: What EC/KBC options are available on this motherboard?
A: The schematic specifies the WPCE8763L as the primary EC, with the WPC8769L(O) listed as an alternate option.
Q: What is the charging IC used on this motherboard?
A: The charging IC is the ISL6251A.
Q: What power ICs are used for voltage regulation?
A: The voltage regulation includes the ISL6237, ISL62882, ISL62881, UP6111AQDD, and TPS51116.
Q: What CPU platforms does this motherboard support?
A: The schematic supports Arrandale (UMA+VGA) and Clarksfield (VGA) processors.
| Project Code | TZ1C |
| Document Number | B2A143 |
| Date | Wednesday, May 27, 2009 |
| CPU Platform | Arrandale (UMA+VGA) / Clarksfield (VGA) |
| PCH / Southbridge | Ibex Peak-M |
| EC / KBC | WPCE8763L |
| EC/KBC Programmable | WPC8769L(O) |
| Audio Codec | CX20583 |
| Charging IC | ISL6251A |
| Power IC(s) | ISL6237, ISL62882, ISL62881, UP6111AQDD, TPS51116 |
| RAM Type | DDR III |
| RAM Architecture | Dual Channel DDR III |
| RAM Quantity / Slots | DDRIII-SODIMM1, DDRIII-SODIMM2 |
| LAN IC | Atheros LAN |
| Card Reader IC | Cardreader/1394 Controller |
| HDMI Level Shifter | HDMI Level Shift |
