toshiba qosmio x755 compal_la-7191p_rev1.0 schematic
toshiba qosmio x755=1=compal_la-7191p_rev1.0.pdf
This Compal PGRAA motherboard, documented under board number LA-7191P revision 1.0 dated 2011-04-26, is built around the Intel Sandy Bridge processor and Cougar Point PCH platform. The system firmware is stored on a 4MB SPI ROM. Embedded controller functions are handled by an ENE KB930 EC, which has a dedicated 128KB EC ROM. Audio is managed by a Realtek ALC269 HDA codec. Networking is provided by a Realtek RTL8111E 1G Ethernet controller. The discrete graphics solution uses an NVIDIA N11E-GS GPU with a 192-bit memory interface and GDDR5 memory. Memory configuration consists of two 200-pin DDRIII SO-DIMM slots supporting dual-channel architecture. Additional I/O controllers include a JMicron JMB389 card reader and a TI TUSB7320 USB 3.0 hub controller.
A: The motherboard uses a single 4MB SPI ROM for BIOS storage.
Q: What EC/KBC is used and is it programmable?
A: The embedded controller is an ENE KB930. The schematic indicates a dedicated 128KB EC ROM, suggesting the EC firmware is stored externally.
Q: What is the discrete GPU configuration?
A: The motherboard uses an NVIDIA N11E-GS GPU with a 192-bit memory interface, supporting 1.5GB or 3GB of GDDR5 memory.
A: It supports DDRIII memory in a dual-channel architecture, using two 200-pin SO-DIMM slots running at 1066/1333 MT/s.
Q: What are the key I/O controllers on this board?
A: The board features a Realtek RTL8111E 1G LAN, a JMicron JMB389 card reader, and a TI TUSB7320 USB 3.0 hub controller.
| Model | PGRAA |
| Board Number | LA-7191P |
| Date | 2011-04-26 |
| CPU Platform | Intel Processor (Sandy Bridge) / PCH (Cougar Point) |
| EC / KBC | ENE KB930 |
| EC Flash / ROM | EC ROM (128KB) |
| Audio Codec | ALC269 |
| BIOS / SPI Flash | SPI ROM (4MB) |
| RAM Quantity / Slots | 200pin DDRIII-SO-DIMM X2 |
| LAN IC | RTL8111E 1G |
| GPU Type | NVIDIA N11E-GS, 192bit with 1.5GB/3GB |
| Graphics Architecture | GDDR5 |
| Card Reader IC | JMB389 |
| USB Hub IC | TUSB7320 |
