toshiba satellite l500-l500d compal_la-5332p_rev1.0 schematic
toshiba satellite l500-l500d=1=compal_la-5332p_rev1.0.pdf
This Compal LA-5332P motherboard, documented under revision 1.0 dated 2009-11-24, is built on the Tigris Platform featuring a Mobile AMD S1G3 CPU paired with an RS880M/RS880MC UMA graphics architecture and an SB710 southbridge. The board utilizes DDRII memory in a dual-channel configuration across two 200-pin SO-DIMM slots. System management is handled by an ENE KB926 D3 embedded controller, with an SPI ROM for BIOS storage. Audio is provided by an ALC272 HDA codec, and networking is managed by a Realtek RTL8103EL 10/100 LAN controller. Power management includes an OZ601 charging IC and an APL5607KI-TRG power IC, while thermal monitoring is performed by an ADM1032ARMZ sensor. Additional notable components include an RTS5159 card reader, an R5F211B4D33SP HDMI CEC controller, an SLG8SP626VTR clock generator, and a TPA6017 audio amplifier.
A: The embedded controller is an ENE KB926 D3.
A: The board supports DDRII memory in a dual-channel configuration via two 200-pin DDRII-SO-DIMM slots.
Q: What LAN controller is used on this motherboard?
A: The LAN controller is a Realtek RTL8103EL 10/100M.
A: The audio codec is an ALC272 HDA codec.
| Project Code | NSWAE/NTWAE LA-5332P |
| Board Number | LA-5332P |
| Date | 2009-11-24 |
| Document Number | 401721C |
| CPU Platform | Mobile AMD S1G3 |
| Platform Alias | Tigris Platform |
| PCH / Southbridge | SB710 |
| GPU Type | RS880M & RS880MC |
| Graphics Architecture | UMA |
| EC / KBC | ENE KB926 D3 |
| Audio Codec | ALC272 |
| BIOS / SPI Flash | SPI ROM |
| Charging IC | OZ601 |
| Power IC(s) | APL5607KI-TRG |
| RAM Type | DDRII |
| RAM Quantity / Slots | 200pin DDRII-SO-DIMM X2 |
| Thermal Sensor | ADM1032ARMZ |
| Card Reader IC | RTS5159 |
| LAN IC | RTL8103EL |
| HDMI Level Shifter | R5F211B4D33SP |
| Clock Generator | SLG8SP626VTR |
| Audio Amplifier | TPA6017 |
LA-5332P
LA-5332P
AMD S1G3
Tigris
SB710
RS880M & RS880MC
UMA
KB926 D3
ALC272
OZ601
APL5607KI-TRG
ADM1032ARMZ
RTS5159
RTL8103EL
R5F211B4D33SP
SLG8SP626VTR
TPA6017
Audio Amplifier
LA-5332P
LA-5332P
AMD S1G3
Tigris
SB710
RS880M & RS880MC
UMA
KB926 D3
ALC272
OZ601
APL5607KI-TRG
ADM1032ARMZ
RTS5159
RTL8103EL
R5F211B4D33SP
SLG8SP626VTR
TPA6017
Audio Amplifier
