toshiba satellite l500-l505 compal_la-5322p_rev1.0 schematic
toshiba satellite l500-l505=1=compal_la-5322p_rev1.0.pdf
This Compal LA-5322P motherboard, documented under document number 401717D revision 1.0 dated 2009-12-22, is designed for the Intel Arrandale CPU platform paired with the Ibex Peak PCH. The system management is handled by an ENE KB926 D3 embedded controller with a dedicated EC ROM. The main BIOS is stored on a SPI ROM. Audio is provided by an ALC272 HDA codec, and networking is handled by an RTL8103EL-VB 10/100M LAN controller. Graphics options include either an ATI M92XTX with a 64-bit memory interface or an ATI M96 Pro with a 128-bit interface, both using DDR3 memory. The charging circuit is managed by an APL5607 IC, and thermal monitoring is performed by an ADM1032ARMZ-25 sensor. A RTS5159EC card reader controller is also integrated.
A: The motherboard uses an ENE KB926 D3 embedded controller with a dedicated EC ROM.
Q: What BIOS flash type is used?
A: The motherboard uses a SPI ROM for the main BIOS.
Q: What LAN controller is used?
A: The motherboard uses a Realtek RTL8103EL-VB 10/100M Ethernet controller.
Q: What are the available GPU configurations?
A: The motherboard supports either an ATI M92XTX with a 64-bit memory interface and 256MB/512MB DDR3, or an ATI M96 Pro with a 128-bit memory interface and 512MB/1GB DDR3.
| Model | NSWAA/NTWAA |
| Project Code | LA-5322P |
| Board Number | LA-5322P |
| Revision | Rev 1.0 |
| Date | 2009-12-22 |
| Document Number | 401717D |
| CPU Platform | Intel Arrandale / IBEX PEAK |
| EC / KBC | ENE KB926 D3 |
| Audio Codec | ALC272 |
| EC Flash / ROM | EC ROM |
| LAN IC | RTL8103EL-VB |
| Card Reader IC | RTS5159EC |
| GPU Type | ATI M92XTX, 64bit with 256M/512MB / ATI M96 Pro, 128bit with 512MB/1GB |
| Graphics Architecture | ATI M92XTX / ATI M96 Pro |
| Thermal Sensor | ADM1032ARMZ-25 |
| Charging IC | APL5607 |
LA-5322P
LA-5322P
Arrandale
Ibex Peak
KB926 D3
ALC272
RTL8103EL-VB
RTS5159EC
64bit with 256M
M92XTX
M96
Pro
ADM1032ARMZ-25
APL5607
LA-5322P
LA-5322P
Arrandale
Ibex Peak
KB926 D3
ALC272
RTL8103EL-VB
RTS5159EC
64bit with 256M
M92XTX
M96
Pro
ADM1032ARMZ-25
APL5607
