toshiba satellite c600d 6050a2414501-mb-a01 abg ct10ab rev 001 2010.11.23
This Inventec CT10AB motherboard, project code Calcutta, board number 48A3CSCT10AB revision A, is built on the AMD Brazos platform featuring an Ontario APU paired with the Hudson M1 FCH. The system supports two DDR3 SODIMM slots for memory expansion. The embedded controller is an NPCE781L, and audio is handled by a CX20671 codec. The BIOS SPI flash is provided by Winbond. Wired networking is managed by an Atheros AR8151 10/100 Gigabit Ethernet controller, while wireless connectivity is handled by an Atheros WLAN module. The charging subsystem is built around a TI BQ24725RGRR battery charger IC in a QFN-20 package.
A: The embedded controller is an NPCE781L.
A: The charging IC is a TI BQ24725RGRR in a QFN-20 package.
A: The audio codec is a CX20671.
A: The LAN IC is an Atheros AR8151.
| Brand | INVENTEC |
| Model | CT10AB |
| Motherboard Manufacturer | INVENTEC |
| Project Code | Calcutta |
| Board Number | 48A3CSCT10AB |
| Revision | A |
| Date | 23-Nov-2010 |
| CPU Platform | AMD BRAZOS PLATFORM |
| CPU Model | Ontario |
| PCH / Southbridge | Hudson M1 |
| EC / KBC | NPCE781L |
| Audio Codec | CX20671 |
| BIOS / SPI Flash | WINBOND |
| Charging IC | TI_BQ24725RGRR_QFN_20P |
| LAN IC | AR8151 |
| WiFi / WLAN IC | Atheros |
| RAM Architecture | DDR3_SODIMM |
