toshiba satellite a80 la-2491 rev 1.0
The Compal Sakhir LA-2491 revision 1.0 motherboard, dated 2004/11/28, is built around the Intel Dothan CPU platform paired with the Intel ICH6-M southbridge. Graphics options include nVIDIA NV43M/NV44M or ATi M22/M24 GPUs. The system uses DDR-1 memory across two DDR-SO-DIMM slots. The embedded controller is an ENE KB910/910L, and the audio codec is an ALC250-D. Networking is handled by a Marvell 88E8036 LAN IC, with wireless connectivity via a Mini PCI socket. The board features a 5in1 card reader, an ADM1032 thermal sensor, and a 88SA8040 USB hub IC. The BIOS is located on a dedicated BIOS page within the schematic.
A: The board number is LA-2491, revision 1.0.
A: The embedded controller is an ENE KB910/910L.
Q: What CPU platform and southbridge does this motherboard use?
A: The CPU platform is Intel Dothan, and the southbridge is Intel ICH6-M.
Q: What type of memory and how many slots are supported?
A: The board supports DDR-1 memory via two DDR-SO-DIMM slots.
| Model | Sakhir LA-2491 |
| Project Code | Sakhir |
| Board Number | LA-2491 |
| Date | 2004 / 11 / 28 |
| CPU Platform | Intel Dothan |
| PCH / Southbridge | Intel ICH6-M |
| GPU Type | nVIDIA NV43M / NV44M / ATi M22 / M24 |
| EC / KBC | ENE KB910/910L |
| Audio Codec | ALC250-D |
| BIOS / SPI Flash | BIOS |
| LAN IC | MARVELL 88E8036 |
| RAM Type | DDR-1 |
| RAM Architecture | DDR-SO-DIMM X2 |
| Thermal Sensor | ADM1032 |
| Card Reader IC | 5in1 CardReader |
| USB Hub IC | 88SA8040 |
| WiFi / WLAN IC | Mini PCI |
| Charging IC | DC/DC Interface CKT. |
| Power IC(s) | Power Circuit DC/DC |
| Document Number | LA-2491 |
