toshiba satellite a80 la-2811 hbt10 rev 1.0
The Compal HBT10 (Sakhir 10E) motherboard, documented under board number LA-2811 revision 1.0 dated 2005-05-04, is built around the uFCBGA/uFCPGA Mobile Dothan CPU platform paired with an ATI-IXP150 southbridge. Graphics are handled by the ATI RL300MB GPU featuring VGA M9 embedded graphics in a BGA 457 package. System management is controlled by an ENE KB910 embedded controller, while audio processing is managed by an ALC 250D codec and an APA2121 audio amplifier. The board utilizes DDR memory architecture with two SO-DIMM slots supporting four banks. The BIOS is a 512K flash device. Charging is managed by a TPS2211AIDBR charger IC. Networking is provided by a Realtek RTL8100CL LAN controller. Thermal monitoring is handled by an ADM1032 sensor. Expansion is supported via a TI-1410 CardBus controller and an NEC USB controller. Clock generation is provided by an ICS951402AGT clock generator.
Q: What is the board number and revision for this Compal HBT10 motherboard?
A: The board number is LA-2811, revision 1.0.
A: The embedded controller is an ENE KB910.
Q: What BIOS flash type is used on this motherboard?
A: The BIOS is a 512K flash device.
A: The charging IC is a TPS2211AIDBR.
A: The LAN IC is a Realtek RTL8100CL.
| Model | HBT10 |
| Project Code | Sakhir 10E |
| Board Number | LA-2811 |
| Date | 2005-05-04 |
| CPU Platform | uFCBGA/uFCPGA Mobile Dothan |
| PCH / Southbridge | ATI-IXP150 |
| GPU Type | ATI RL300MB |
| Graphics Architecture | VGA M9 Embeded BGA 457 pin |
| EC / KBC | ENE KB910 |
| Audio Codec | ALC 250D |
| BIOS / SPI Flash | BIOS(512K) |
| Charging IC | TPS2211AIDBR |
| RAM Type | DDR |
| RAM Architecture | SO-DIMM x2 |
| RAM Quantity / Slots | BANK 0,1,2,3 |
| Thermal Sensor | ADM1032 |
| Card Reader IC | TI-1410 CARDBUS |
| LAN IC | RTL8100CL |
| Audio Amplifier | APA2121 |
| Clock Generator | ICS951402AGT |
| USB Controller | NEC USB Controller |
| PCB Number | LA-2811 |
| Document Number | DA600001K10 |
10E
LA-2811
Dothan
IXP150
RL300MB
KB910
ALC250D
TPS2211AIDBR
DDR
ADM1032
1410 CARDBUS
RTL8100CL
APA2121
ICS951402AGT
10E
LA-2811
Dothan
IXP150
RL300MB
KB910
ALC250D
TPS2211AIDBR
DDR
ADM1032
1410 CARDBUS
RTL8100CL
APA2121
ICS951402AGT
