toshiba satellite a505 chelsea 10m ddr3 cs10m 6050a2256301 mb rev x01 ws 2009.06.12
This Inventec CS10M motherboard, documented under board number 6050A2250201 and revision A02, is built around the Intel Penryn CPU platform paired with the Cantiga GPU and ICH9-M southbridge. The system memory architecture supports two DDR2 SODIMM slots. The embedded controller is a WPCE775x, and the system BIOS is provided by a Winbond SPI flash IC. Audio is handled by a Realtek ALC268 codec. Networking capabilities include dual LAN controllers, a Realtek RTL8102EB and an RTL8111C, alongside a Boardcom wireless LAN module. The charging subsystem utilizes a TI BQ24721C controller with an AM4825P 90W charger architecture, supported by a power management IC set including TPS51125, TPS51117, TPS51620, and APL5913. Additional integrated controllers include a Ricoh R5C833 card reader, an ICS9LPRS365 clock generator, and a Silicon Image Sil9181 HDMI level shifter.
A: The board number is 6050A2250201, and the revision is A02.
A: The embedded controller is a WPCE775x.
Q: What BIOS flash IC is used on this motherboard?
A: The BIOS flash IC is from Winbond.
Q: What is the charging IC and charger architecture?
A: The charging IC is a TI BQ24721C, and the charger architecture is an AM4825P rated at 90W.
| Brand | Inventec |
| Model | CS10M |
| Project Code | CS10M |
| Board Number | 6050A2250201 |
| Revision | A02 |
| Date | 16-Apr-2009 |
| Document Number | 1030A22502-0-MTR |
| CPU Platform | Penryn |
| GPU Type | Cantiga |
| EC / KBC | WPCE775x |
| Audio Codec | ALC 268 |
| BIOS / SPI Flash | Winbond |
| Charging IC | TI_BQ24721C_QFN_32P |
| Charger Architecture | AM4825P (90W) |
| Power IC(s) | TPS51125, TPS51117, TPS51620, APL5913 |
| RAM Type | DDR2 |
| RAM Architecture | DDR2 Interface |
| Card Reader IC | RICOH_R5C833 |
| LAN IC | RTL8102EB, RTL8111C |
| WiFi / WLAN IC | Boardcom |
| HDMI Level Shifter | Sil9181 |
| Clock Generator | ICS9LPRS365 |
CS10M
6050A2250201
Penryn
ICH9
Cantiga
WPCE775X
ALC268
BQ24721C_QFN_32P
APL5913
TPS51117
TPS51125
TPS51620
RICOH R5C833
RTL8102EB
RTL8111C
Boardcom
SIL9181
ICS9LPRS365
CS10M
6050A2250201
Penryn
ICH9
Cantiga
WPCE775X
ALC268
BQ24721C_QFN_32P
APL5913
TPS51117
TPS51125
TPS51620
RICOH R5C833
RTL8102EB
RTL8111C
Boardcom
SIL9181
ICS9LPRS365
