toshiba inventec chelsea cs10g mp 2091104 ti map
This Inventec Chelsea 10G motherboard, board number 6050A2256201 revision A02, is designed for the Clarkfield and Arrandale CPU platforms. The system uses DDR III memory in SODIMM0 and SODIMM1 slots. Graphics are handled by a discrete Nvidia VGA solution. The embedded controller is a WINB781, and the audio codec is an ALC272. Power management is handled by a BQ24721C charger IC and multiple power ICs including TPS51125, TPS51218, TPS51621, RT9194, RT8015APQW, and PM6652. Networking is provided by RTL8103E and RTL8111DP LAN ICs, and the card reader controller is a RICOH_R5U230.
A: The embedded controller is a WINB781.
A: The charging IC is a BQ24721C.
Q: What type of memory does this motherboard use?
A: This motherboard uses DDR III memory in SODIMM0 and SODIMM1 slots.
Q: What is the graphics architecture of this motherboard?
A: This motherboard uses a discrete Nvidia VGA graphics solution.
| Brand | Inventec |
| Project Code | Chelsea 10G |
| Board Number | 6050A2256201 |
| Revision | A02 |
| Date | 2009-10-08 |
| CPU Platform | Clarkfield / Arrandale |
| EC / KBC | WINB781 |
| Audio Codec | ALC272 |
| Charging IC | BQ24721C |
| Power IC(s) | TPS51125, TPS51218, TPS51621, RT9194, RT8015APQW, PM6652 |
| RAM Type | DDR III |
| RAM Architecture | SODIMM0, SODIMM1 |
| LAN IC | RTL8103E, RTL8111DP |
| Card Reader IC | RICOH_R5U230 |
| GPU Type | Nvidia VGA |
| Graphics Architecture | Discrete Graphic |
10G
6050A2256201
Arrandale
Clarkfield
WINB781
ALC272
BQ24721C
PM6652
RT8015APQW
RT9194
TPS51125
TPS51218
TPS51621
RTL8103E
RTL8111DP
RICOH R5U230
Nvidia VGA
Discrete Graphic
10G
6050A2256201
Arrandale
Clarkfield
WINB781
ALC272
BQ24721C
PM6652
RT8015APQW
RT9194
TPS51125
TPS51218
TPS51621
RTL8103E
RTL8111DP
RICOH R5U230
Nvidia VGA
Discrete Graphic
