toshiba qosmio x305-q725 ksraa ls-4471p nb9e-compal vga tx rev 2.0
This Compal Electronics, Inc. document, LS-4471P Revision 2.0 dated 2008-06-20, details the NVIDIA NB9E-GTX GDDR3 VGA BOARD. The graphics architecture is configured as 1G (32M*32 8 Pcs) x 2 Frame Buffer, utilizing GDDR3 memory with 16M*32 organization across eight pieces. The board features an ADM1032ARMZ-2REEL thermal sensor for temperature monitoring. The block diagram illustrates the NB9E-GTX GPU interfacing with DDR memory channels A, B, C, and D, each with 16M*32 memory chips, and a PCI Express connection via an ACES_88396-1G41 connector. The design includes spread spectrum clocking via an ASM3P2872A and a 27MHz clock source.
Q: What is the document number and revision of this Compal VGA board?
A: The document number is LS-4471P, Revision 2.0, dated 2008-06-20.
Q: What GPU and memory architecture does this board use?
A: The board uses an NVIDIA NB9E-GTX GPU with a 1G (32M*32 8 Pcs) x 2 Frame Buffer GDDR3 memory architecture.
Q: What thermal sensor is used on this board?
A: The thermal sensor is an ADM1032ARMZ-2REEL.
| Document Number | LS-4471P |
| Revision | 2.0 |
| Date | 2008-06-20 |
| GPU Type | NVIDIA NB9E-GTX GDDR3 VGA BOARD |
| Graphics Architecture | 1G(32M*32 8 Pcs) x 2 Frame Buffer |
| RAM Type | GDDR3 |
| RAM Architecture | 16M*32 |
| RAM Quantity / Slots | 8 Pcs |
| Thermal Sensor | ADM1032ARMZ-2REEL |
