toshiba l640 daote2mb6fo da0te2mb6e0 1
This Quanta TE2 project motherboard, documented under number 2A135 dated March 10, 2010, is built around the Intel Arrandale CPU platform with integrated graphics (UMA+VGA) connected via DMI(x4) to the Ibex Peak-M PCH. The system supports dual-channel DDRIII memory via two DDRIII-SODIMM slots operating at 800/1066/1333 MHz. Power management is handled by an ISL88731A charging IC alongside multiple power ICs including RT8210B, UP6111A, RT8152C, RT015A, ISL62882C, and UP6163. The motherboard features an ITE EC/KBC, an integrated audio codec, a Giga/10/100 LAN controller, a card reader, and an HDMI level shifter. Clock generation is provided by the SLG8SP595VTR clock generator.
Q: What is the CPU platform and PCH used on this motherboard?
A: The CPU platform is Intel Arrandale (UMA+VGA) and the PCH is Ibex Peak-M, connected via DMI(x4).
A: It supports dual-channel DDRIII memory via two DDRIII-SODIMM slots at 800/1066/1333 MHz.
A: The charging IC is the ISL88731A.
Q: What clock generator is used on this motherboard?
A: The clock generator is the SLG8SP595VTR.
| Project Code | TE2 |
| Document Number | 2A135 |
| Date | Wednesday, March 10, 2010 |
| CPU Platform | Arrandale (UMA+VGA) |
| PCH / Southbridge | Ibex Peak-M |
| GPU Type | Integrated Graphics (UMA+VGA) |
| Graphics Architecture | DMI(x4) |
| RAM Architecture | Dual Channel DDR III |
| RAM Quantity / Slots | DDRIII-SODIMM1, DDRIII-SODIMM2 |
| EC / KBC | ITE (EC/KBC) |
| Audio Codec | Audio Codec |
| LAN IC | Giga/10/100 Lan |
| Charging IC | ISL88731A |
| Power IC(s) | RT8210B, UP6111A, RT8152C, RT015A, ISL62882C, UP6163 |
| Card Reader IC | Cardreader |
| HDMI Level Shifter | HDMI Level Shift |
| Clock Generator | SLG8SP595VTR |
