Schematic toshiba compal ls-3443p nb8e-se ddr3 vga boardd rev-1a schematic
toshiba compal ls-3443p nb8e-se ddr3 vga boardd rev-1a 1
BrandCompal
Project Code4059G5C
Board NumberLS-3443P
Revision1.A
Date2007-06-22
Document Number4059G5C
GPU TypenVIDIA NB8E-SE
Graphics ArchitectureDDR3
RAM TypeDDR3
RAM Architecture16M*32
RAM Quantity / Slots4 pcs / 8 pcs
Thermal SensorADM1032ARMZ-2REEL
This Compal Electronics LS-3443P schematic, revision 1.A, dated June 22, 2007, documents a VGA/B motherboard under project code 4059G5C. The platform is built around an nVIDIA NB8E-SE DDR3 GPU. The frame buffer configuration supports either 256MB using four 16M*32 Samsung K4D553235F-GC2A chips or 512MB using eight of the same chips. A thermal sensor, the ADM1032ARMZ-2REEL, is integrated for temperature monitoring. The board utilizes a PCI Express interface and includes LVDS bus support for display output.
Q: What is the board number and revision of this schematic?
A: The board number is LS-3443P, revision 1.A.
Q: What GPU is used on this motherboard?
A: The GPU is an nVIDIA NB8E-SE with DDR3 memory architecture.
A: It supports either 256MB (4 pcs of 16M*32) or 512MB (8 pcs of 16M*32) frame buffer using Samsung K4D553235F-GC2A chips.
Q: What thermal sensor is used on this board?
A: The thermal sensor is an ADM1032ARMZ-2REEL.
  • Toshiba=1=Compal_LS-3443P_NB8E-SE_DDR3_VGA_Boardd_Rev-1A.pdf
