Schematic toshiba ac100 compal la-6352p rev1.0a schematic
toshiba ac100 compal_la-6352p_rev1.0a schematic
toshiba ac100=1=compal_la-6352p_rev1.0a.pdf
BrandCompal
ModelPAZ00
Document Number332008/09/202006/08/18C
Revision1.0a
Date2010-07-15
CPU PlatformNvidia Tegra T20
EC / KBCENE KBC KB926
Audio CodecALC5632
BIOS / SPI FlashSPI ROM
Charging ICTI TPS658621
Power IC(s)Intersil 29011
RAM TypeDDR2 SDRAM
RAM Architecturefour x4 DDRII
RAM Quantity / Slots4
Thermal SensorADI ADT7421
Card Reader ICSN75LVDS83
USB Hub ICSMSC USB 2514, SMSC USB 2512
LAN ICUSB3315
WiFi / WLAN ICWIFI
HDMI Level ShifterI2C LEVEL Shifter
GPU TypeNvidia Tegra T20
Graphics ArchitectureLVDS
The Compal PAZ00 motherboard, revision 1.0a, is built around the Nvidia Tegra T20 platform with four x4 DDRII memory configuration using DDR2 SDRAM across four slots. System management is handled by an ENE KBC KB926 EC/KBC, with the BIOS stored on a SPI ROM. Power management is provided by a TI TPS658621 charger IC and an Intersil 29011 DC/DC interface. Audio is managed by an ALC5632 codec driving a TPA6017 audio amplifier. Connectivity includes an SMSC USB 2514 and SMSC USB 2512 USB hub ICs, a USB3315 USB PHY for LAN, and an integrated WIFI module. Display output is via an SN75LVDS83 LVDS bridge, with an I2C level shifter for HDMI. Thermal monitoring is performed by an ADI ADT7421 sensor. The board also integrates an ST19NP18 TPM, a BMA150 G-sensor, and supports eMMC storage.
A: The ENE KBC KB926 is used as the EC/KBC.
A: The charging IC is a TI TPS658621.
A: The audio codec is an ALC5632.
Q: What USB hub ICs are used on this motherboard?
A: The board uses an SMSC USB 2514 (4-port) and an SMSC USB 2512 (2-port) USB hub ICs.
  • Toshiba AC100=1=compal_la-6352p_Rev1.0a.zip
