Acer Aspire 2420 2920 Wistron calado Rev1.0 Schematic
This Wistron Calado-1 motherboard, project code 91.4X401.001 with board number 07227 revision -1, is built around the Intel GM965 or GL960 chipset paired with an ICH8M southbridge. The platform supports a Merom or Celeron M mobile CPU in a 479-pin package. System memory is DDR2 running at 533 or 667 MHz. The embedded controller is a Winbond WPC8763L, and the BIOS SPI flash is a W25X80-V in an SSBIOS package. Audio is handled by a Realtek ALC268 codec. The charging subsystem uses a MAX8731 charger controller with a MAX8770 for battery management. Power regulation is managed by multiple ICs including TPS51120, TPS51124, TPS51100, APL5915, and APL5913. Integrated graphics are provided by the GM965 (GMA X3100) or GL960 (GMA 3000). Networking is via a Broadcom BCM5787MKMLG gigabit LAN controller, and a Realtek RTS5158 5-in-1 card reader is included.
A: The BIOS SPI flash is a Winbond W25X80-V in an SSBIOS package.
A: The embedded controller is a Winbond WPC8763L.
Q: What is the charging architecture on this motherboard?
A: The charging subsystem uses a MAX8731 charger controller combined with a MAX8770 for battery management.
A: This motherboard supports DDR2 memory running at 533 or 667 MHz.
| Project Code | 91.4X401.001 |
| Board Number | 07227 |
| Revision | -1 |
| Date | Thursday, September 13, 2007 |
| CPU Platform | Intel GM965/GL960 |
| PCH / Southbridge | ICH8M |
| EC / KBC | WPC8763L |
| EC/KBC Manufacturer | Winbond |
| Audio Codec | ALC268 |
| BIOS / SPI Flash | W25X80-V |
| BIOS Flash Package | SSBIOS |
| Charging IC | MAX8731 |
| Charger Architecture | MAX8770 |
| Power IC(s) | TPS51120, TPS51124, TPS51100, APL5915, APL5913 |
| RAM Type | DDR2 |
| RAM Architecture | 533/667 MHz |
| LAN IC | BCM5787MKMLG |
| Card Reader IC | RTS5158 |
| GPU Type | Integrated Graphics |
| Graphics Architecture | Intel GMA X3100 (GM965) / GMA 3000 (GL960) |
91.4X401.001
07227
GL960
GM965
ICH8M
WPC8763L
ALC268
W25X80-V
MAX8731
APL5913
APL5915
TPS51100
TPS51120
TPS51124
BCM5787MKMLG
RTS5158
91.4X401.001
07227
GL960
GM965
ICH8M
WPC8763L
ALC268
W25X80-V
MAX8731
APL5913
APL5915
TPS51100
TPS51120
TPS51124
BCM5787MKMLG
RTS5158
