toshiba a200 a203 a205 mw10 milwaukee 10 pre mp build 070320 6050a2109401 1310a21094 1
The Inventec Milwaukee 10 motherboard, documented under board number A021310A2109401 revision A02, is built around the Intel Merom CPU platform paired with the ICH8-M southbridge. System memory consists of two DDR2 SODIMM slots. The embedded controller is a Winbond W8769D, and the BIOS is stored on an SPI EEROM. Audio is handled by a Realtek ALC 268 codec, while networking is provided by a Marvell 10/100 8039 LAN controller and an Atheros AR5BXB63 wireless module. The charging subsystem is managed by a TI BQ24721 QFN 32 system charger and battery IC. A Realtek RTS365 card reader controller and a Sil1392 HDMI level shifter are also present on this platform.
Q: What EC/KBC is used on the Inventec Milwaukee 10?
A: The embedded controller is a Winbond W8769D.
Q: What type of BIOS flash is used on this motherboard?
A: The BIOS is stored on an SPI EEROM.
Q: What charging IC is used on the Inventec Milwaukee 10?
A: The charging IC is a TI BQ24721 in a QFN 32 package.
Q: What is the memory configuration for this motherboard?
A: The motherboard supports two DDR2 SODIMM modules.
| Model | Milwaukee 10 |
| Motherboard Manufacturer | Inventec |
| Project Code | Milwaukee 10 |
| Board Number | A021310A2109401 |
| Revision | A02 |
| Date | 20-Mar-2007 |
| CPU Platform | Merom |
| PCH / Southbridge | ICH8-M |
| EC / KBC | Winbond W8769D |
| Audio Codec | ALC 268 |
| BIOS / SPI Flash | SPI EEROM |
| Charging IC | TI BQ24721 QFN 32 |
| Charger Architecture | System Charger & Battery |
| RAM Type | DDR2 |
| Card Reader IC | Realtek RTS365 |
| LAN IC | Marvell 10/100 8039 |
| WiFi / WLAN IC | Atheros AR5BXB63 |
| HDMI Level Shifter | Sil1392 |
| Drawing Number | CSA3633 |
| Document Number | 1310A2109401 |
