toshiba a200 6050a2120801-mb-a02 schematic
toshiba a200=1=6050a2120801-mb-a02.pdf
The Inventec Milwaukee 10M (Project Code MW10M, Board Number CSA3531, Revision A02) is a laptop motherboard designed for the Intel Yonah CPU platform. It utilizes the Intel 945GM/943GML graphics and ICH7-M southbridge, supporting two DDR2 SODIMM slots. The system is powered by a TI BQ24721 charging IC and a TI TPS51020 system power IC. The embedded controller is a Winbond W8763L, and the audio codec is a Realtek ALC268. Networking is handled by a Marvell 10/100 8039 LAN controller, with a Wireless LAN BTO module. The board features a TI 4512 USB hub controller, a TI 8402 Cardbus controller, and a 1394 controller. The clock generator is an ICS9LPR316. The BIOS is stored on an SPI EEROM. The battery connector is an ACES 91202-0047L_TSB_4P, protected by a LITTLEFUSE R451015 15A 65V fuse. Thermal monitoring is provided by a GMT G680LT1 sensor.
A: The board number is CSA3531, and the project code is MW10M (Milwaukee 10M).
A: The embedded controller is a Winbond W8763L.
A: The charging IC is a TI BQ24721.
A: The audio codec is a Realtek ALC268.
A: The LAN controller is a Marvell 10/100 8039.
| Brand | Inventec |
| Model | Milwaukee 10M |
| Project Code | MW10M |
| Board Number | CSA3531 |
| Revision | A02 |
| Date | 12-Jan-2007 |
| CPU Platform | Yonah |
| PCH / Southbridge | ICH7-M |
| GPU Type | 945GM / 943GML |
| EC / KBC | W8763L |
| Audio Codec | ALC268 |
| BIOS / SPI Flash | SPI EEROM |
| Charging IC | TI BQ24721 |
| RAM Type | DDR2 |
| RAM Architecture | SODIMM |
| LAN IC | Marvell 10/100 8039 |
| WiFi / WLAN IC | Wireless LAN BTO |
| Card Reader IC | Card reader BTO |
| USB Hub IC | TI 4512 |
| Cardbus Controller | TI 8402 |
| 1394 Controller | 1394 Controller |
| Clock Generator | ICS9LPR316 |
| System Power IC | TI TPS51020 |
| Battery Connector | ACES 91202-0047L_TSB_4P |
| Fuse | LITTLEFUSE R451015 15A 65V |
| Thermal Sensor | GMT G680LT1 |
| Document Number | 310A2120801 |
MW10M
CSA3531
Yonah
ICH7
943GML
945GM
W8763L
ALC268
BQ24721
10/100 8039
4512
1394 CONTROLLER
Bridge / Expander
ICS9LPR316
GMT G680LT1
MW10M
CSA3531
Yonah
ICH7
943GML
945GM
W8763L
ALC268
BQ24721
10/100 8039
4512
1394 CONTROLLER
Bridge / Expander
ICS9LPR316
GMT G680LT1
