sony vaio flip 14n svf14n quanta fi2_rev1a schematic
sony vaio flip 14n svf14n=1=quanta fi2_rev1a.pdf
This Quanta FI2 motherboard is built on the Intel Shark Bay Haswell ULT platform with a LynxPoint-LP PCH. The system memory consists of a single DDR3L-1600 SO-DIMM module on channel A. The embedded controller is an NPCE985L, and the audio subsystem is managed by a Realtek ALC233-CG codec. The BIOS is stored on an 8MB SPI ROM. Power management is handled by an ISL88732 battery charger, with voltage regulation provided by NCP81101, TPS51427, and G5602R41U controllers. The board integrates a Realtek RTL8111G Gigabit LAN controller, a Realtek RTS5227E SD card reader, and a WLAN/BT module on PCIe port 20. Display connectivity includes eDP and HDMI, with an HDMI level shifter IC. The system also features a sensor hub with an STM32F103CBU6 microcontroller and various environmental sensors.
Q: What EC/KBC is used on this Quanta FI2 motherboard?
A: The embedded controller is an NPCE985L.
A: The BIOS is stored on an 8MB SPI ROM.
A: The battery charger IC is an ISL88732.
A: The board supports one DDR3L-1600 SO-DIMM module on channel A.
| Brand | Quanta |
| Project Code | FI2 |
| Date | Wednesday, August 14, 2013 |
| CPU Platform | Intel Shark Bay Haswell ULT + LynxPoint-LP |
| EC / KBC | NPCE985L |
| Audio Codec | ALC233-CG |
| BIOS / SPI Flash | SPI ROM 8MB |
| Charging IC | ISL88732 |
| Power IC(s) | NCP81101, TPS51427, G5602R41U |
| RAM Type | DDR3L-1600 |
| RAM Architecture | SO-DIMM |
| RAM Quantity / Slots | 1 |
| Card Reader IC | RTS5227E |
| LAN IC | RTL8111G |
| WiFi / WLAN IC | WLAN/BT P20 |
| HDMI Level Shifter | P13HDMI |
