sony vaio flip 14n svf14n quanta fi2_da0fi2mb6d0 schematic
sony vaio flip 14n svf14n=1=quanta fi2_da0fi2mb6d0.pdf
The Quanta FI2 motherboard is built on the Intel Shark Bay platform with a Haswell ULT processor and LynxPoint-LP PCH. The system firmware is stored on an 8MB SPI ROM. Embedded controller functions are handled by an NPCE985L. Audio is managed by a Realtek ALC233-CG codec. The charging subsystem is based on an ISL88732 charger IC. Power regulation is provided by NCP81101, TPS51427, and G5602R41U controllers. Memory configuration consists of a single DDR3L-1600 SO-DIMM channel. Wired networking is supported by a Realtek RTL8111G Gigabit LAN controller. A Realtek RTS5227E card reader is integrated. The integrated Haswell ULT graphics drives an eDP display output.
A: The EC/KBC is an NPCE985L.
A: The BIOS is stored on an 8MB SPI ROM.
A: The charging IC is an ISL88732.
Q: What is the audio codec used?
A: The audio codec is a Realtek ALC233-CG.
| Brand | Quanta |
| Project Code | FI2 |
| Board Number | FI2 |
| Revision | 1A |
| Date | Wednesday, August 14, 2013 |
| CPU Platform | Intel Shark Bay Haswell ULT + LynxPoint-LP |
| EC / KBC | NPCE985L |
| BIOS / SPI Flash | SPI ROM 8MB |
| Audio Codec | ALC233-CG |
| Charging IC | ISL88732 |
| Power IC(s) | NCP81101, TPS51427, G5602R41U |
| RAM Type | DDR3L-1600 |
| RAM Architecture | SO-DIMM Channel A |
| LAN IC | RTL8111G |
| Card Reader IC | RTS5227E |
| WiFi / WLAN IC | WLAN/BT |
| HDMI Level Shifter | HDMI |
| GPU Type | Haswell ULT (Integrated) |
| Graphics Architecture | eDP |
