samsung np-r18_np-r18 plus_np-r20_np-r20 plus_np-r25_np-r25 plus hainan2_rev1.0 schematic
samsung np-r18_np-r18 plus_np-r20_np-r20 plus_np-r25_np-r25 plus=1=hainan2_rev1.0.pdf
This Samsung Hainan2 motherboard is built on the Intel Merom CPU platform with an RS600M and SB600 chipset. The system uses a Hitachi H8S-2110B EC/KBC and an MX25L8005 SPI flash for BIOS storage. Audio is handled by an ALC262 codec, while networking is provided by an RTL8100CL LAN IC. The charging architecture is managed by a MAX1909ETI+T charger IC, supported by multiple power ICs including MAX8734AEEI+, MAX8734B, ISL6227CAZ-T, MAX8632ETI+, SC452, and MIC5219B. Memory configuration consists of two DDR II SODIMM slots operating in single-channel mode. A card reader IC (AU6366) and an ICS95461 clock generator are also present on this board.
Q: What BIOS flash IC is used on this motherboard?
A: The BIOS SPI flash is an MX25L8005.
A: The EC/KBC is a Hitachi H8S-2110B.
A: The charging IC is a MAX1909ETI+T.
Q: What is the memory configuration on this motherboard?
A: The board supports two DDR II SODIMM modules in a single-channel architecture.
| Brand | Samsung |
| Model Name | HAINAN2 |
| Motherboard Manufacturer | Samsung Electronics |
| PBA Name | MAIN |
| PCB Code | BA41-XXXXXA |
| Date | November 2, 2006 |
| CPU Platform | Intel Merom |
| Chip Set | RS600M & SB600 |
| EC / KBC | Hitachi H8S-2110B |
| Audio Codec | ALC262 |
| BIOS / SPI Flash | MX25L8005 |
| LAN IC | RTL8100CL |
| Charging IC | MAX1909ETI+T |
| Power IC(s) | MAX8734AEEI+, MAX8734B, ISL6227CAZ-T, MAX8632ETI+, SC452, MIC5219B |
| RAM Type | DDR II |
| RAM Architecture | Single channel |
| Card Reader IC | AU6366 |
| Clock Generator | ICS95461 |
Merom
HITACHI H8S/2110B
ALC262
MX25L8005
RTL8100CL
MAX1909ETI+T
ISL6227CAZ-T
MAX8632ETI
MAX8734AEEI
MAX8734B
MIC5219B
SC452
AU6366
ICS95461
Merom
HITACHI H8S/2110B
ALC262
MX25L8005
RTL8100CL
MAX1909ETI+T
ISL6227CAZ-T
MAX8632ETI
MAX8734AEEI
MAX8734B
MIC5219B
SC452
AU6366
ICS95461
