Schematic Asus PRIME Z790M-PLUS D5 Schematic
BrandASUSTek COMPUTER INC.
ModelPRIME Z790M-PLUS D5
Project NameSKYLAKE CHIPSET DEMO
RevisionR1.00
DateThursday, October 20, 2022
CPU PlatformIntel Processor (LGA-1700 Pin Socket)
PCH / SouthbridgeINTEL RPL
Audio CodecRealtek ALC897
LAN ICIntel I219V
Super I/ONCT6798D
BIOS / SPI FlashSPI FLASH
HDMI Level ShifterASM1442K
USB Hub ICGL850
USB RedriverGL9905
USB RedriverPI3EQX1002E
USB-C ControllerASM1543
RAM TypeDDR5
RAM ArchitectureChannel A / Channel B
VR ControllerISL99390
VR ControllerISL69269
VR ControllerAPW8723AQBI-TRG
VR ControllerUP8815PDA
VR ControllerAPL5337KAI-TRG
VR ControllerNCP302045
VR ControllerRT7276GQW
VR ControllerRT6541A
VR ControllerAPW8743
VR ControllerRT6543AGQW
The ASUS PRIME Z790M-PLUS D5 motherboard, revision R1.00 dated October 20, 2022, is built on the Intel RPL PCH platform supporting LGA-1700 socket Intel processors. The board features dual-channel DDR5 memory architecture and integrates a Realtek ALC897 audio codec and an Intel I219V LAN controller. System monitoring and control are handled by an NCT6798D Super I/O. The BIOS is stored on a SPI flash device. Display connectivity includes an ASM1442K HDMI 2.1 level shifter. USB expansion is supported by a GL850 USB 2.0 hub, GL9905 and PI3EQX1002E USB redrivers, and an ASM1543 USB-C controller. The voltage regulation subsystem employs multiple controllers including ISL99390, ISL69269, APW8723AQBI-TRG, UP8815PDA, APL5337KAI-TRG, NCP302045, RT7276GQW, RT6541A, APW8743, and RT6543AGQW for core, GT, SA, IO, VCCST, VCCSTG, VTTDDR, VPPDDR, and auxiliary rails.
Q: What audio codec is used on the PRIME Z790M-PLUS D5?
A: The motherboard uses a Realtek ALC897 audio codec.
Q: What LAN controller is integrated on this board?
A: The board features an Intel I219V LAN controller.
A: The PRIME Z790M-PLUS D5 supports DDR5 memory in a dual-channel (Channel A / Channel B) architecture.
Q: What Super I/O chip is used for system monitoring?
A: The board uses an Nuvoton NCT6798D Super I/O.
Q: What HDMI level shifter is present on this board?
A: The board includes an ASM1442K HDMI
  • Asus PRIME Z790M-PLUS D5 Schematic.pdf
