Asus Prime B760M-KS Schematic
This ASUSTek X99 Deluxe motherboard, documented under project SKYLAKE CHIPSET DEMO revision R1.00, is engineered for the Intel ALDER LAKE platform using an LGA-1700 Pin Socket. The platform is supported by an INTEL RKL PCH and utilizes an NCT6798D EC/KBC for system management. Memory architecture consists of four DDR4 DIMM slots configured in dual channel, supporting speeds from 2133 up to 3200 MHz. Integrated audio is handled by a Realtek ALC897 codec, while networking is provided by an Intel I225V LAN IC. The board features an ASM1442 HDMI level shifter and a GL852 USB hub IC. Power delivery is managed by a combination of controllers including NCP81166AMNTBG and NCP81270MNTXG VR controllers, alongside multiple power ICs such as RT7276GQW, RT9081DGQZA, and RT8125DGQW. The charging IC is an RT9088AGQW. Wireless connectivity is supported via a CNVI interface.
A: The motherboard uses an NCT6798D EC/KBC.
Q: What audio codec is integrated on this board?
A: The integrated audio codec is a Realtek ALC897.
Q: What LAN controller is present on this motherboard?
A: The LAN controller is an Intel I225V.
A: The board supports DDR4 memory in a dual-channel configuration across four DIMM slots, with speeds up to 3200 MHz.
| Brand | ASUSTek COMPUTER INC. |
| Model | X99 Deluxe |
| Motherboard Manufacturer | ASUSTek COMPUTER INC. |
| Project Name | SKYLAKE CHIPSET DEMO |
| Revision | R1.00 |
| Date | Wednesday, December 21, 2022 |
| CPU Platform | ALDER LAKE |
| CPU Socket | LGA-1700 Pin Socket |
| PCH / Southbridge | INTEL RKL PCH |
| EC / KBC | NCT6798D |
| Audio Codec | Realtek ALC897 |
| LAN IC | Intel I225V |
| RAM Architecture | Dual Channel (Channel A, Channel B) |
| RAM Quantity / Slots | 4 DIMMs |
| RAM Speed | 2133/2400/2666/2933/3200 |
| USB Hub IC | GL852 |
| HDMI Level Shifter | ASM1442 |
| Charging IC | RT9088AGQW |
| Power IC(s) | UP0132P, UP1540PDDA, RT7276GQW, RT9081DGQZA, RT8125DGQW, NCP81166AMNTBG, NCP81270MNTXG |
| VR Controller | NCP81166AMNTBG, NCP81270MNTXG |
| WiFi / WLAN IC | CNVI |
| Document Number | A25132 |
Alder Lake
LGA-1700
NCT6798D
ALC897
I225V
GL852
ASM1442
RT9088AGQW
NCP81166AMNTBG
NCP81270MNTXG
RT7276GQW
RT8125DGQW
RT9081DGQZA
UP0132P
UP1540PDDA
Alder Lake
LGA-1700
NCT6798D
ALC897
I225V
GL852
ASM1442
RT9088AGQW
NCP81166AMNTBG
NCP81270MNTXG
RT7276GQW
RT8125DGQW
RT9081DGQZA
UP0132P
UP1540PDDA
