MSI MS-95L6 Rev 10 0b Schematic
This MSI motherboard, identified by board number MS-95L6, is documented under revision 2006/04/03 update with a document number of Custom13, dated Friday, May 19, 2006. The board utilizes a QS3126 EC/KBC controller in a QSOP16 package. The EC flash/ROM is provided by an AT24C256N-10SU-2.7-RHA EEPROM. The schematic details extensive management and debug interfaces including LPC, SMBus, ICMB, and OPMA support, alongside video capture and DVI connectivity.
Q: What is the board number for this motherboard?
A: The board number is MS-95L6.
A: The EC/KBC controller is a QS3126 in a QSOP16 package.
Q: What is the EC flash/ROM model on this motherboard?
A: The EC flash/ROM is an AT24C256N-10SU-2.7-RHA EEPROM.
This document, dated Friday, July 28, 2006, with a revision of 2006/04/03 update, is titled LPC SMBUS Video Capture DVI-I DEBUG MCARD Serial Port DEBUG Interface Type ID DEBUG Control Misc Card Detect Single Wire Analog Sensors Control Power Multi-Bank Fan Control Multiplexed Fan Tachometers Multiplexed Fan Tachometers Control TX/RX for SOL Support LED Control USB Bottons TX/RX SOL Ctrl ICMB Status Mgmt LAN OPMA SO-DIMM_FINGER. The board number is CN1. The schematic includes an AT24C256N-10SU-2.7-RHA EEPROM at reference U8 and QS3126Q_QSOP16 analog switches at references U1 and U7.
Q: What EEPROM IC is used on this board?
A: The EEPROM IC is an AT24C256N-10SU-2.7-RHA at reference U8.
Q: What analog switch ICs are present?
A: The QS3126Q_QSOP16 analog switch ICs are present at references U1 and U7.
| Brand | MSI |
| Board Number | MS-95L6 |
| Date | Friday, May 19, 2006 |
| Revision | 2006/04/03 update |
| Document Number | Custom13 |
| EC / KBC | QS3126 |
| EC/KBC Package | QSOP16 |
| EC Flash / ROM | AT24C256N-10SU-2.7-RHA |
| Document Number | <Doc><RevCode><Title>Custom |
| Date | Friday, July 28, 2006 |
| Title | LPC SMBUS Video Capture DVI-I DEBUG MCARD Serial Port DEBUG Interface Type ID DEBUG Control Misc Card Detect Single Wire Analog Sensors Control Power Multi-Bank Fan Control Multiplexed Fan Tachometers Multiplexed Fan Tachometers Control TX/RX for SOL Support LED Control USB Bottons TX/RX SOL Ctrl ICMB Status Mgmt LAN OPMA SO-DIMM_FINGER |
| Board Number | CN1 |
| EEPROM IC | AT24C256N-10SU-2.7-RHA |
| EEPROM IC Reference | U8 |
| Analog Switch IC | QS3126Q_QSOP16 |
| Analog Switch IC Reference | U1, U7 |
