Schematic MSI MS-95L6 Rev 10 0b Schematic
BrandMSI
Board NumberMS-95L6
DateFriday, May 19, 2006
Revision2006/04/03 update
Document NumberCustom13
EC / KBCQS3126
EC/KBC PackageQSOP16
EC Flash / ROMAT24C256N-10SU-2.7-RHA
This MSI motherboard, identified by board number MS-95L6, is documented under revision 2006/04/03 update with a document number of Custom13, dated Friday, May 19, 2006. The board utilizes a QS3126 EC/KBC controller in a QSOP16 package. The EC flash/ROM is provided by an AT24C256N-10SU-2.7-RHA EEPROM. The schematic details extensive management and debug interfaces including LPC, SMBus, ICMB, and OPMA support, alongside video capture and DVI connectivity.
Q: What is the board number for this motherboard?
A: The board number is MS-95L6.
A: The EC/KBC controller is a QS3126 in a QSOP16 package.
Q: What is the EC flash/ROM model on this motherboard?
A: The EC flash/ROM is an AT24C256N-10SU-2.7-RHA EEPROM.
Document Number<Doc><RevCode><Title>Custom
DateFriday, July 28, 2006
TitleLPC SMBUS Video Capture DVI-I DEBUG MCARD Serial Port DEBUG Interface Type ID DEBUG Control Misc Card Detect Single Wire Analog Sensors Control Power Multi-Bank Fan Control Multiplexed Fan Tachometers Multiplexed Fan Tachometers Control TX/RX for SOL Support LED Control USB Bottons TX/RX SOL Ctrl ICMB Status Mgmt LAN OPMA SO-DIMM_FINGER
Board NumberCN1
EEPROM ICAT24C256N-10SU-2.7-RHA
EEPROM IC ReferenceU8
Analog Switch ICQS3126Q_QSOP16
Analog Switch IC ReferenceU1, U7
This document, dated Friday, July 28, 2006, with a revision of 2006/04/03 update, is titled LPC SMBUS Video Capture DVI-I DEBUG MCARD Serial Port DEBUG Interface Type ID DEBUG Control Misc Card Detect Single Wire Analog Sensors Control Power Multi-Bank Fan Control Multiplexed Fan Tachometers Multiplexed Fan Tachometers Control TX/RX for SOL Support LED Control USB Bottons TX/RX SOL Ctrl ICMB Status Mgmt LAN OPMA SO-DIMM_FINGER. The board number is CN1. The schematic includes an AT24C256N-10SU-2.7-RHA EEPROM at reference U8 and QS3126Q_QSOP16 analog switches at references U1 and U7.
Q: What EEPROM IC is used on this board?
A: The EEPROM IC is an AT24C256N-10SU-2.7-RHA at reference U8.
Q: What analog switch ICs are present?
A: The QS3126Q_QSOP16 analog switch ICs are present at references U1 and U7.
  • MSI MS-95L6 Rev 0b_0518_1050 Schematic.pdf
  • MSI MS-95L6 Rev 10 Schematic.pdf
